Differential equation: Spring/Mass system of driven motion with damping
The discussion focuses on solving a differential equation for a spring/mass system subjected to damping and external driving forces. The weight of 32 pounds stretches the spring 2 feet, leading to a mass of 1 slug and a spring constant k of 16 lb/ft. The damping coefficient β is determined to be 8, representing the damping force of 8 times the instantaneous velocity. The final equation of motion is established as d²x/dt² + 8(dx/dt) + 16x = 2cos(5t), which can be solved using the Laplace transform.
  • Understanding of differential equations and their applications in physics.
  • Familiarity with spring/mass systems and Hooke's Law (F = kx).
  • Knowledge of damping forces and their representation in equations.
  • Proficiency in using Laplace transforms for solving differential equations.
  • Study the derivation of the spring constant using Hooke's Law.
  • Learn about the application of Laplace transforms in solving second-order differential equations.
  • Explore the concept of damping in mechanical systems and its mathematical representation.
  • Investigate the effects of external forces on spring/mass systems through driven motion analysis.
Students in physics or engineering courses, particularly those studying dynamics, mechanical systems, or differential equations. This discussion is also beneficial for anyone looking to understand the behavior of damped oscillatory systems.
TeenieBopper
A 32 pound weight stretches a spring 2 feet. The mass is then released from an initial position of 1 foot below the equilibrium position. The surrounding medium offers a damping force of 8 times the instantaneous velocity. Find the equation of motion if the mass is driven by an external force of 2cos(5t).
F=kx
m=W/g
m[itex]\frac{d^{2}x}{dt^{2}}[/itex]+[itex]\beta[/itex][itex]\frac{dx}{dt}[/itex]+kx=f(t)
I found that k=16[itex]\frac{lb}{ft}[/itex] and m=1 slug. This gets me the following equation:
[itex]\frac{d^{2}x}{dt^{2}}[/itex]+[itex]\beta[/itex][itex]\frac{dx}{dt}[/itex]+16x=2cos(5t)
I'm at a loss for how to determine [itex]\beta[/itex], which is the damping force of 8 times the instantaneous velocity. I don't know how to determine instantaneous velocity. I know that once I have [itex]\beta[/itex], I can just use a LaPlace transform to find x(t). But [itex]\beta[/itex] is my stumbling block right now.
As I was writing this, it occurred to me that [itex]\frac{dx}{dt}[/itex]=instantaneous velocity and that would make [itex]\beta[/itex]=8. That in turn makes the problem very easy to solve. Am I correct in this thinking?
We kind of rushed through this application in class the other day. Thanks in advance for any help you're able to provide.
TeenieBopper said:
As I was writing this, it occurred to me that [itex]\frac{dx}{dt}[/itex]=instantaneous velocity and that would make [itex]\beta[/itex]=8. That in turn makes the problem very easy to solve. Am I correct in this thinking?.
Yeah I would agree that β=8 here. Just make sure your initial conditions are correct with the proper signs.
  • · Replies 105 ·
13K
  • · Replies 18 ·
