Solving Polynomial Question: Find m Given 2 Rational Roots
  • Context: Undergrad
  • Thread starter Thread starter uart
    Polynomial
The discussion revolves around the polynomial equation x^3 + m x^2 + 15 x - 7, specifically focusing on determining the value of m given that the polynomial has at least two rational roots. Participants explore the implications of whether m must be an integer and the assumptions involved in solving the problem.
  • One participant suggests that since the product of the roots is 7, having two rational roots implies that the third root must also be rational.
  • Another participant argues that assuming m is an integer simplifies the problem and leads to a unique solution, but questions whether this assumption is necessary or can be deduced.
  • A later reply questions the uniqueness of the solution and asks if there is a theorem that would imply m must be an integer given the conditions of the polynomial.
  • One participant provides an example to illustrate that m does not need to be an integer, but another participant points out a mistake in the example, leading to a discussion about the validity of rational solutions.
  • Another participant expresses uncertainty about proving that the only rational solution for x and y is the integer solution (x=1, y=1) after correcting the equation.
  • One participant proposes a more complex condition for rationality involving perfect squares, indicating the difficulty of finding rational solutions.
  • Another participant raises the possibility that m could be a non-constant term, but this is countered by a clarification that m is assumed to be a constant coefficient in the context of polynomials.
Participants do not reach a consensus on whether m must be an integer. Multiple competing views remain regarding the assumptions necessary for solving the polynomial and the nature of its coefficients.
There are unresolved assumptions regarding the nature of m and the conditions under which rational roots exist. The discussion reflects varying interpretations of polynomial properties and the implications of rational root conditions.
uart
Somebody gave me the following question, I was able to solve it but was unsure about some of the assumptions involved.
Question : Given that the polynomial x^3 + m x^2 + 15 x - 7 has at least two rational roots then find m.
Now the question didn't state that m had to be integer and I was unsure as to whether this was meant to be assumed or whether it could be deduced.
Here's what I did.
1. Since the product of the roots is 7 then two rational roots implies that the third root is also rational.
2. I assumed that m was integer which meant that the rational roots where also integer. ( by the http://planetmath.org/encyclopedia/RationalRootTheorem.html )
3. Since there are very few ways of having integer roots that multiply to give 7 I easily found the possible roots of 7, 1, 1, that multiply to give 7 and also have sum of pair-products totalling to 15.
4. So m = -(7 + 1 + 1) = -9
So did I need to assume that m was integer or could it have been deduced?
Mathematics news on Phys.org
You've found an m that satisfies the requirements. What does it matter that you assumed m was integer? It makes it easier and gives a unique solution, but so what? Had the assumption not yielded an answer then you couldn't conclude no solution existed, but that's all.
7=xyz
15=xy+xz+yz
15=xy+x(7/xy)+y(7/xy)=xy+7y+7x
so let x=2,
15=2y+7y+14, so y=1/9, and hence z=63/2 would also work, so it is neither necessary for m to be an integer, nor is it deducible that m is one.
Yes I know that the solution is ok, and I'm sure it was the intended solution, but I am still uncertain as to whether it's unique.
Is there any theroem that would have implied that m had to be integer once I had all three roots rational, all other coefficients integer, and a monic polynomial ?
See my example, in the above edited post. Clearly it is not necessary for m to be an integer, and cannot be deduced.
Thanks Matt, that's just what I wanted to know. :)
Hang on Matt, there is a mistake in that example.
It should be 15 = xy + 7/x + 7/y.
x=2 leads to a quadratic with irrational solutions for y.
It's also clear that the choice of x=2 was completely arbitrary, and any rational would have yielded an answer.
With the corrected equation (15 = xy + 7/x + 7/y), I don't think there is any possible rational solution for x and y other than the integer solution (x=1, y=1). I'm not sure how to prove that though.
Damn, buggered that one up then.
need 15xy=x^2y^2 +7y+7x, so y is rational iff (7-15x)^2 - 28x^3 has rational square root (for some rational x) which seems too hard to solve, so I think we should assume that they meant that m was an integer, but let's try: we need to find a/b=x such that
(7b-15a)^2/b^2 - 28a^3/b^3 is a perfect square, If we let b be a square number, then it suffices (though is not necessary) that
b(7b-15a)^2-28a^3 is also a square. Anyone any suggestions?
In general though there is no theorem that states: if P is a monic poly with rational roots, then all but one coeff integer implies the last one must be: consider
x^2 - ax+1, If a=2, then there are two integer solutions, though in general
a=p+q where p=1/q and p is any rational will do, and I don't see it changing generally for higher degree polys: it really will depend on the poly in question.
What if m=-x? No one said it was a constant.
It was stated that it is a polynomial. And, polynomials are in the form of [tex]a_{n}x^{n} + a_{n-1}x^{n-1} + a_{n-2}x^{n-2}+...+a_{2}x^{2}+a_{1}x^{1}+a_{0}[/tex] where the a's are constant coefficients. So it is assumed that "m" in his problem would be a constant coefficient.
  • · Replies 18 ·
  • · Replies 0 ·
  • · Replies 17 ·
