Is There Any Significant Difference Between Gravitational and Coulomb Forces?
The discussion revolves around the differences and similarities between gravitational and Coulomb forces, particularly in the context of electrostatic potential energy and gravitational potential energy. Participants explore theoretical aspects, potential energy changes, and the implications of motion on these forces.
  • Some participants propose that electrostatics and Newtonian gravity are equivalent under certain conditions, particularly when considering potential energy changes.
  • Others argue that while electrostatics can be approximated in static scenarios, it becomes invalid when charges or fields are in motion, contrasting this with Newtonian gravity which does not have such limitations.
  • A participant suggests that both gravitational and electrostatic potential energy can be analyzed using a hypothetical electron as a test charge, questioning if energy calculations yield different results at varying speeds.
  • There is a discussion about the notation used for mass and charge, with some participants clarifying their definitions and assumptions regarding unit mass and charge.
  • One participant emphasizes that the change in potential energy is equal to the change in kinetic energy, regardless of whether the context is electrostatics or gravity.
  • Concerns are raised about the implications of using a unit charge versus a fundamental charge in experiments, highlighting the importance of minimizing disturbances in electric fields.
Participants express differing views on the equivalence of gravitational and electrostatic forces, particularly in dynamic scenarios. There is no consensus on how motion affects the validity of electrostatic principles compared to gravitational principles.
Participants note limitations in their assumptions, such as the ideal conditions for the hypothetical scenarios discussed and the potential discrepancies arising from different speeds and charges. The discussion also reflects varying interpretations of fundamental concepts in physics.
This discussion may be of interest to those exploring the foundational principles of physics, particularly in understanding the relationships between gravitational and electrostatic forces, as well as the implications of motion on potential energy. It may also benefit individuals studying theoretical physics or engaging in conceptual debates within the field.
formal
The definition of Δ (difference,drop of) Electrostatic Potential Energy (D E-PE) says it
'is the work done on a unit charge (e) to bring it from r to r1 (against the force) with constant (without acceleration) velocity and extremely low absolute value of velocity (quasistatic, vanishingly small, etc..)
afaik, v must be steady not to create magnetic disturbances or the like.
It escapes me what would happen if value of v is , say, 1 cm/s. (constant)
(We can shoot an electron in a G Field at 1 Km/ s without problems, and get exact D G-PE)
Could you explain this to me, possibly without formulas? I need only to grasp the general idea!
Thanks
(* to simplify discussion let's assume the following ideal conditions:
A positive charge in vacuum distant from Galaxies equivalent of GM ( 0.0000184 C ?)at the origin r(o) and
one electron (e) at r = r(earth) = 6.4x 10^6 m moving to r1 at v= 1 cm (m, km?)/ s)
formal said:
The definition of Δ (difference,drop of) Electrostatic Potential Energy (D E-PE) says it...
I'm not sure I understand the question, or how the question follows from the subject, but I'll give it a shot anyway: if the question is (a) whether electrostatics (via the coulomb potential) and Newtonian gravity are equivalent, then the answer is Yes, with the caveat that the "charge" in the case of gravity is not only always attractive, but is also the same quantity that determines how much energy it takes to accelerate the body (internal = gravitational mass).
If on the other hand the question is (b) if they're still the same when motion is involved, the answer would be ERROR: electrostatics isn't valid if your charges / fields are moving / changing; though of course the smaller the speed / charge / fields, the smaller the difference between the actual physics and the electrostatic approximation gets -- but in Newtonian gravity, as far as I know, there is no such limitation (particularly since Newton formulated it knowing that he was working with fast-moving "particles").
jjustinn said:
1) if the question is (a) whether electrostatics (via the coulomb potential) and Newtonian gravity are equivalent, then the answer is Yes,
2) If on the other hand the question is (b) if they're still the same when motion is involved, the answer would be ERROR: .
Hi jjustinn,
Both questions are related because
both in G-field (A) and E-field (B) one electron -e (which is at same time both unit-mass / unit-charge)) is
1) at rest at r(1) and then
2) moves falls towards M /(+charge) at origin r(o) until it bangs into something at r (e)
Can you separate the two sides of the issue? :confused:
I assume that when it reaches r (=r(e)) it has the same energy Ek in G or E-field.
I proposed an example because that is the best way to cancel any doubt.
if you set r = 6.4 x10^8 cm (= r(earth)) and r1 = 10^ 9 or any value you wish, you can figure out Ek (D PE) in both cases.
Then you take the same -e as test charge and move it against the charge
from r to r(1) and see if you get different values at different speeds.
just an additional question:
as in the example (B) charge = 1 can we say that D E-PE = Ek = Voltage (PE/ 1) ?
An electron is not assumed to have a unit mass and I don not think that it 'bangs' into something at r. Our concern is to just get it to r and not to see that it gets there and stops or so!
formal said:
Hi jjustinn,
I think part of my problem is I don't follow your notation...
In electrostatics or Newtonian gravity, the change in a particle's potential energy is equal to the change in its kinetic energy. So if a particle with q = 1C starts at rest (kinetic energy = 0J) any position with V = 10V, then its potential energy = 10J. If it moves to any other position where V = 0V -- one meter away, or 10.551*10^6 light-years away, if we're only dealing with electrostatics, its potential energy will be 0J, so its kinetic energy will be 10J.
The same argument works exactly the same if you replace volts (electrostatic potential energy per coulomb) with gravitational potential energy and coulombs (C) with kilograms (kg).
thebiggerbang said:
An electron is not assumed to have a unit mass!
Unit mass in the example, not Unit in dimensional analysis:smile:
see next post
I'm awfully sorry, jjustinn,:redface:
unit is a very tricky word!
I'll call it our unit*
it is -charge 1.6022x 10^ -19 C
and at the same time 9.1x 10^- 31 kg
OK?
now if r = 6.4 x 10^6 (acc=9.8, PE 6.25 x10^7); and r1 = 10^ 7 (acc=4, PE= 4x10^7)
when unit* falls from r1 to r gains D PE* (6.25 - 4 = 2.25) v at r = 6.7 km/s
if we shoot it up from r at 6.7 km/s it will reach r1 and loose exactly PE°,
now you say what happens if we shoot unit* in a similar E-field
and why the result is different
Thanks
OK?
when it moves at any speed from r to r1 loses always same PE*
if this is at last clear, move on to voltage, please!
AFAIK,in the definition the unit charge is a 1C charge and not a charge of e (that is the fundamental unit of charge). But while experimenting, they using a vanishingly small charge to avoid disturbing the existing EF.
formal is a previously banned crackpot, sorry that you had to deal with his nonsense.
  • · Replies 19 ·
