| New Reply |
How does force travel actually? |
Share Thread | Thread Tools |
| Aug10-11, 09:25 AM | #1 |
Force is a push or pull. Is it just the transfer of energy from one body to another? If yes, why does it mostly result in the acceleration of the body?
If no, then how does force travel? |
| Aug10-11, 09:45 AM | #2 |
http://en.wikipedia.org/wiki/Momentu...ions_of_motion http://en.wikipedia.org/wiki/Momentu...s_and_velocity The notion that "forces cause acceleration" is a philosophical one. Physics merely states that net force and acceleration are proportional, and the proportionality constant is called mass. |
| Aug10-11, 10:38 AM | #3 |
Force is not a property of an object, but instead is an interaction between objects (object A exerts a force on object B and vice versa), so as such it doesn't really travel.
| Aug10-11, 11:24 AM | #4 |
I didnt exactly understand that how do the objects interact with each other causing acceleration .
| Aug10-11, 11:46 AM | #5 |
Hi Akash:
I'm assuming you are asking an introductory question. In general terms you CAN think of a force as transferring energy....sometimes it causes acceleration, sometimes not. For example if I kick a ball, it moves and may go flying some distance; If I kick a brick wall I might deform the wall a tiny bit, but I might also deform my foot by breaking it. In all three cases energy is transfered...in the first it's momentum/acceleration that mostly results, in the latter in the form of heat as I compress the wall or my foot....(Of course you deform the ball briefly as you kick it,too) Which I touch something like in the above examples, electrons in my foot repel electrons in the object. That can also happen over distances as in electrical repulsion or attraction force: F = Kq1q2/r2 With such field forces, the force (really the energy) is carried by the electromagnetic field which can be considered particles and or waves....the particle view uses photons as the quanta of the electromagnetic field..... There are other force fields as the strong,weak and magnetic as well. In some cases it's not obvious just what energy if any is being transferred, as in an electron orbital moving around a nucleus....Our standard equation which I gave above does NOT explain such interactions.... |
| Aug11-11, 07:39 AM | #6 |
o..o..ok....thanks
| Aug11-11, 08:02 AM | #7 |
It's a bad idea to think of force as a transfer of energy between bodies because while it appears so, that is not what actually happens, strictly speaking. As A.T. rightly put it, it is more of a transfer of momentum. |
| Aug11-11, 10:12 AM | #8 |
| Aug11-11, 10:21 AM | #9 |
If you push a trolly, you feel the same force (in the opposite direction) to your push, but the friction of your shoes stops you moving in the opposite direction.
Think about what happens at the fundemental level between the contact point of your hands with the handle of the trolley. |
| Aug11-11, 10:39 AM | #10 |
Of course the gradient of Potential Energy is directly related to Force; but, while force can be defined in terms of energy, force isn't the transfer of energy per se, rather it is via a transfer of momentum that a form of energy conversion becomes apparent. |
| Aug11-11, 10:53 AM | #11 |
| Aug11-11, 10:54 AM | #12 |
I can state the difference between K.E. and momentum by their definitions, but intuitively to me they are very similar. Someone care to explain the differences in real life situations?
| Aug11-11, 10:58 AM | #13 |
In this context, to put it simply, KE arises as a result of momentum. Initially, a body has Potential Energy (say) then one applies a force, transfers momentum which, in turn, introduces a KE in the body.
| Aug11-11, 11:11 AM | #14 |
Force changes the physical state like motion,position,So that it most results in acceleration.It push or pull the object changing the physical states like velocity and displacement and distance.so that it causes some change in velocity in a particular interval of time.That is nothing but Acceleration.
| Aug11-11, 11:45 AM | #15 |
| Aug11-11, 12:58 PM | #16 |
| Aug11-11, 01:45 PM | #17 |
Yes, it may sound philosophical, but giving something a 'name' doesn't mean we know it or it has been explained. On the contrary, sometimes we hide the 'reason' by giving it a 'name'. |
| New Reply |
| Tags |
| energy, force, medium, motion, transfer |
| Thread Tools | |
Similar Threads for: How does force travel actually?
| A question with masses and distance to travel, find the time to travel so far... | Introductory Physics Homework | 5 | ||
| Time travel and space travel | Special & General Relativity | 9 | ||
| Calculating the travel time in relativistic travel | Special & General Relativity | 1 | ||
| Free body diagram involving normal force, gravitational force, and applied force. | Introductory Physics Homework | 4 | ||
