| New Reply |
transition probability for a step function perterbation |
Share Thread | Thread Tools |
| Aug10-11, 09:38 AM | #1 |
a particle with mass=m is in a 1-D infinite square well of width a. The particle is initially in ground state. A delta function potential V1=k δ(x-a/2) is turned on at t= -t1 and turned off at t=t1. A measurement is made at t2, where t2>t1. What is the probability that the particle will be found in the third excited state (n=3)? 2. Relevant equations recall the normalized solution to schodinger's eq for the unperturbed infinite square well: Psi(x) = sqrt(2/a)sin(npix/a), E(n)= ((h/2pi)(pi)(n))^2/(2ma^2); n=1,2,3... P(i -> f) = 1/hbar^2 (<psi(final) lHl psi(initial)>)^2(integral of f(t)e^(i(E(final)-E(initial))t/hbar)dt from t(initial) to t(final) 3. The attempt at a solution the wave function is subject to H(t); H(t) can be factored into a time independent operator, H, and a time dependent piece, f(t), which does not operate on the wave function. hence H(t) = Hf(t) It would be really annoying to type out my work so ill try and explain what I am stuck on. V1 basically acts as an infinite potential barrier at x= a/2. I initially tried solving shrodingers eq with V(x) = V1. My intuition tells me that in order to solve this differential equation I need to use a Laplace transformation, however when I try to work it out, I get an answer that I know isnt correct (i.e. psi(x) = 0). So I scraped that plan and solved schodingers eq for two wave functions, one for (0<x<a/2) and the second for (a/2<x<a). This worked out ok; I was not sure how to pick the coefficients for each wave function, im assuming they need to be continuos at x=a/2, but also equal to zero at x=0, x=a/2,x=a ? Furthermore, for the relation H(t) = Hf(t), I am not sure what H or f(t) are. Since I took took the δ(x-a/2) into account by deriving two wave functions, I made an educated guess and took H=k, and f(t) =1 (-t1<t<t1) and f(t)=0 (t1<t<t2). I put all this mess into the equation given above for P(i -> f) and simplified, continued simplifying, and eventually decided to request assistance from the internet. Usually our HW problems aren't this tedious so I think I probably set the problem up completely wrong. Can anyone share some wisdom to a tired, haggard undergrad? 1. The problem statement, all variables and given/known data 2. Relevant equations 3. The attempt at a solution |
| Aug15-11, 05:01 AM | #2 |
In case you do want to solve for the eigenstates when the perturbation is turned on, the boundary conditions are (1) ψL(0)=ψR(a)=0; (2) ψL(a/2)=ψR(a/2); and (3) ψ'R(a/2)-ψ'L(a/2) = some constant, where the two wave functions are the solutions for the left and right halves of the well. You can figure out what the constant is by integrating the Schrodinger equation from x=a/2-ε to x=a/2+ε. The wave function remains continuous at x=a/2, but the delta function causes a discontinuity in the derivative. |
| New Reply |
| Thread Tools | |
Similar Threads for: transition probability for a step function perterbation
| Transition Probability | Advanced Physics Homework | 2 | ||
| Tchebysheff proof, help understanding transition to last step | Set Theory, Logic, Probability, Statistics | 11 | ||
| Transition Probability | Advanced Physics Homework | 6 | ||
| Transition Probability for a Laser system | Quantum Physics | 4 | ||
| Probability of transition in hydrogen atom | Advanced Physics Homework | 1 | ||
