Projectile motion apple throw problem
The problem involves projectile motion, where a child throws an apple core from a height of 4.0 meters with an initial velocity of 5.0 m/s at an angle of 35 degrees above the horizontal. The questions focus on the time it takes for the apple core to hit the ground, the horizontal distance it travels, and its velocity upon impact.
  • Mixed
  • Participants discuss the use of kinematic equations to solve for time, distance, and final velocity. There are mentions of using the quadratic formula and concerns about rounding errors in calculations. Some participants question the choice of signs in their equations and the assumptions made regarding the coordinate system.
There is ongoing dialogue about the calculations and methods used, with some participants providing feedback on rounding and suggesting alternative approaches. Several participants express confusion about their results and seek clarification on the application of the equations.
Participants are grappling with the implications of their chosen coordinate system and the signs of the terms in their equations. There are indications of differing interpretations regarding the height of the landing point and the acceleration due to gravity.
phee
A child sitting in a tree throws his apple core from where he is perched (4.0m high) with a velocity of 5.0 m/s [35 degrees above horiztontal], and it hits the ground right next to his friend.
A) How long is it before the apple core hits the ground?
B) How far from the base of the tree will the apple core land?
C) What is the velocity of the apple core on impact?
part A) I used dy= Viy x t + 1/2(ay)(t)^2
part B) I used dx = (Vx)(t)
part C) I used Vf^2 = Viy^2 + 2ay(dy)
Then Pythagorean theorem to find out the final velocity and tan function to find the angle
My answers were as follows:
A) 1.27 second
B) 5.2m
C) 9.9 m/s @ 65.5 degrees below horizontal
Any feedback is greatly appreciated.
It is all right, but there are rounding errors. Use more significant digits during calculations.
ehild
A) 1.27 second
B) 5.2m
Your rationale is correct! However, I have a few minor suggestions -
1. For A), B), and C), I agree with ehild, there are rounding problems. My results for A) are 1.23s (for g=-10) or 1.24s (for g=-9.8).
2. For C), why not using Vyfinal=Vyinitial-g*t? I think this makes calculation easier, as you avoid doing sq root.
Oh good! I know how to do this. Sounds like a problem I had trouble with, but I remember a really good way to figure it out. So, as long as you know that dy=vi,yt + 1/2gt^2 then you could figure out time. since the apple core falls 4 meters below the point of full quadratic motion (basically 4 meters below the y point in which it returns),
-4meters= vi,yt +1/2gt^2
vi,y=5m/s(sin35) and plug that in and use the quadratic formula to find time and use common sense to determine which time makes more sense. and use that time to find distance which is easy.
As for the third question, let's see v^2=v0^2 + 2adx and v=v0 + gt and v^2=v0^2 + 2gdy
So, on impact, v^2=(5.0m/s)^2 +2g(-4meters)
Figure out velocity from there :)
Urgh, How are you guys getting 1.23 I don't know what I am doing wrong??
for time I use
4 = 2.86m/s x t + 1/2(9.8 m/s^2) t^2
I keep getting 1.27s
Can anyone point out where I am going wrong? This is killing me
for time I use
Can you explain the terms in your equation? How do the signs of the terms in your equation relate to your chosen coordinate system?
dy =vi,y x t + 1/2 a,y x t^2
Explain your choice of signs for each of the terms.
I got the 4 from the height (dy) of the child.
2.86m/s from 5m/s x Sin35
t = unsolved for
9.8 m/s^2 = acceleration due to gravity
t = unsolved for
So... The apple core is going to land 4 meters higher than the child in the tree, and is accelerated upwards at a rate of 9.8m/s2?
No it will land 4 m below the child on the ground, and it is thrown at an angle of 35 degrees at 5m/s
Does your equation reflect those details?
I don't think so, should it be -4 m dor dy and -9.8 m/s ^ 2 for ay?
Yup! :smile:
gneill said:
Yup! :smile:
That still gives me 1.27s though. I still don't know what I am doing wrong to keep being .3s off the times that others are getting.
Can you show your calculations?
My original calculations were:
4 m = 2.86 m/s x t + 1/2 (-9.8m/s ^2) t^2
4 m = 1/2(-9.8m/s^2) t^2
This is in square root, don't know how to do on the forum:
t = 2(4m) / (9.8m/s^2)
t = 1.27s
You've still assumed that the landing point is above the launch point.
What happened to the velocity term (t) ?
t = 1.27s
You need to use the full quadratic formula here. There's a "t" as well as a "t2" term to deal with.
The first t is negated out because its unknown which takes away the 2.86 m/s right?
I will redo the equation now with the negatives in what I believe is the way to do it.
-4m = 2.86 m/s x t + 1/2 (-9.8 m/s ^2) t^2
-4m = 1/2 (-9.8 m/s ^ 2) t^2
t^2 = -4m / 1/2(9.8 m/s^2)
And from square rooting the answer of that I get error on my calculator. :(
No. The term must stay. The t is the unknown that you're solving for.
The equation is of the form
[tex]at^2 + bt + c = 0[/tex]
solve for t.
Stupid post
phee said:
Two of the ts would cancel out leaving one alone, ugh it slipped by me.
:confused:?
gneill said:
:confused:?
Im so lost, so the equation I have been using is wrong?
It's not wrong. Once you've got the signs of the terms straightened out it's fine. But you can't just drop terms that are part of it.
Rearrange the equation into the form I showed and plug the coefficients into the quadratic formula to solve for t.
hey Phee, go back to my post if you want. I explained that you should use the quadratic formula. as long as 0=ax^2 + bx + c then you can solve for x using a particular quadratic formula
so if 0 = 1/2(-9.81m/s^2)t^2 + 2.86 m/s t + 4m you can solve for t using
(-b +/- sqrtb^2-2ac)/2a=t
a=-4.905
b=2.86
c=4
since at^2 + bt + c=0
I also am having troubles with this problem.
I keep getting answers similar to 1.07 s which i know is not correct.
This is how i have been doing the problem:
dv=viyXt+1/2(9.8m/s)^2(t)^2
-4m=(2.86m/s)(t)+1/2(9.8m/s)^2(t)^2
t=square root of: t (-4) / -9.8+2.86
=1.07 s
Can someone please advise me as to what I am doing wrong? I have been working at this question for a while now.
The acceleration due to gravity should be in the downward direction!
I am still getting 1.07 s as my answers even after putting the acceleration due to gravity as a negative. I keep getting answers similar to 1.07 s which i know is not correct.
dv=viyXt+1/2(-9.8m/s)^2(t)^2
-4m=(2.86m/s)(t)+1/2(-9.8m/s)^2(t)^2
t=square root of: 2(-4) / -9.8+2.86
=1.07 s
I am still unsure of where I am going wrong can someone please clarify
Can you explain how you're going from the equation of motion to the t = square root... part? I don't recognize the application of the quadratic equation there.
Also, be careful with your units for the acceleration g. You've written (-9.8m/s)^2, which is not correct. First, the units of g are m/s2. Second, g shouldn't be squared here, only the time is squared on the acceleration term of the equation of motion.
I used this reply as reference "hey Phee, go back to my post if you want. I explained that you should use the quadratic formula. as long as 0=ax^2 + bx + c then you can solve for x using a particular quadratic formula
a=-4.905
b=2.86
c=4
since at^2 + bt + c=0"
and interpretted it into my equation...
-2.86 +/- sqrt 2.86^2-2(-4.906)(4) / 2(-4.905)
-2.86 - sqrt 8.1796+39.248 / -9.81
=-1.43
I keep finding that each time I do the equation I get a different answer. I think I am having the most trouble finding the proper equation
  • · Replies 21 ·
