Create Sound-Activated LED Circuit: Subwoofer & Floor Speakers
  • Thread starter Thread starter jheiges
    Leds Sound
This discussion focuses on creating a sound-activated LED circuit for subwoofers and floor speakers. The proposed setup involves using red LEDs for the subwoofer and blue LEDs for the left and right floor speakers, but the speaker wire lacks sufficient voltage to activate the LEDs directly. Participants recommend using a voltage regulator and suggest a non-invasive monitoring circuit with transistors or op-amps to amplify audio signals. Key components include high-pass filters, differential amplifiers, and comparators to ensure accurate LED activation based on audio signal thresholds.
  • Understanding of audio signal processing
  • Familiarity with electronic components such as transistors and op-amps
  • Knowledge of filter design, specifically high-pass and low-pass filters
  • Basic circuit design principles, including power supply considerations
  • Research "transistor amplifier circuits" for audio signal processing
  • Learn about "high-pass and low-pass filter design" for audio applications
  • Explore "comparator circuits" for signal threshold detection
  • Investigate "voltage regulator circuits" to ensure proper LED operation
Electronics enthusiasts, audio engineers, and hobbyists interested in integrating visual indicators with audio systems will benefit from this discussion.
jheiges
So I was wondering how to create a sound activated LED circuit for each of my speakers. I want the red LEDs to light up when the subwoofer is activated and the blue LEDs to light up when the left and right floor speakers are activated. I had a thought about wiring the LEDs parellel to in input for the speakers like in the picture below but there is not enough voltage in the speaker wire to activate my LEDs. I was thinking a voltage regulator may work but I do not know much and could not find much information online. Thanks for the help. Below is a picture of the set up I was thinking about.
Are different audio signals sent to the different speakers? Or does each different speaker contain a filter (crossover) network to select what frequencies to emphasize?
If all the speakers are receiving the same audio drive signal, then you will need to do your own filter circuit to determine which speakers are driving the most sound out, before you have your LED drive circuits monitoring.
And regardless, your LED monitoring circuits should be non-invasive for the audio signal, so they should have their own power supply, and they should use a transitor or opamp amplification stage that connects to the audio drive signals (so there is very small loading of the audio signals). You would use comparators after the initial buffer stages (possibly with filter circuits) to detect when the drive for a speaker is above some threshold, and use the outputs of the comparators to drive the LEDs...
There is something crutial that is missing from what berkeman has described. You problably want the LED current to be related to something such as the average power of the audio signal for some period of time, and not simply have LED current flow whenever the signal exceeds a constant value.
Here are some options:
signal from speaker wire --> high pass filter --> differential amplifer --> multiply signal with itself ---> low pass filter --> comparator ---> (LED + resistor)
signal from speaker wire --> high pass filter --> differential amplifer --> rectifier/absolute value --> low pass filter --> comparator ---> (LED + resistor)
The high pass would be to remove any 0 frequency (also referred to as "DC") offset.
One would have to do calculations to make sure you won't exceed the power supply voltages for the active stages, that the LED receives the right current, that the highpass does not significantly attenuate audio signals of interest, and the lowpass filter will provide decent smoothing without sacrificing the responsiveness.
Additionally it would not be a bad idea to verify the LED current is within the comparator's output current capability (if it isn't you can fix this with another stage).
As berkeman posted, you will may have to add additional filtering if you are connecting before an internal filter contained within the speaker housing.
  • · Replies 26 ·
