Finding recursive relations in Mathematica
  • Context: Mathematica
  • Thread starter Thread starter mnb96
    Mathematica Relations
This discussion focuses on finding recursive relations for a sequence of polynomials defined in Mathematica, specifically using the k-th derivative of the exponential function of a quadratic polynomial, s(x) = ax² + bx + c. The user employs the code D[Exp[s[x]], {x, k}] to generate polynomials P_k(x) and seeks to express P_k in terms of previous polynomials. The solution involves using DifferenceRoot and RecurrenceTable, with the latter proving more efficient for symbolic calculations. The discussion concludes with a recommendation to explore generating functions for a broader understanding of recursion relations.
  • Familiarity with Mathematica programming language
  • Understanding of polynomial derivatives and series expansions
  • Knowledge of recurrence relations and their applications
  • Basic concepts of generating functions in combinatorial mathematics
  • Learn about Mathematica's DifferenceRoot function for solving recurrence relations
  • Explore the RecurrenceTable function in Mathematica for symbolic computations
  • Study generating functions and their role in recursion relations
  • Investigate the properties of Hermite polynomials and their recursive definitions
Mathematics students, researchers in combinatorics, and Mathematica users interested in polynomial sequences and recursive relations.
mnb96
Hello,
I have a sequence of polynomials defined in the following way:
P_k(x) = \frac{\partial^k}{\partial x^k}e^{s(x)}\vert_{x=0}
Essentially the polynomial Pk is the k-th derivative of \exp(s(x)) evaluated at x=0. The function s(x) is a polynomial of 2nd degree in x.
In mathematica I define the polynomials with the following code:
For k=1..n one obtains a list of n polynomials P1(x),...,Pn(x).
My question is: is it possible to ask Mathematica to find a recurrent relation that expresses any Pk as a function of the previous polynomials Pk-1, Pk-2... ? (assuming it exists).
A similar well-known problem exists for http://en.wikipedia.org/wiki/Hermite_polynomials#Definition"
Thanks.
Try
Code:
In[1]:= s[x_] := a x^2+b x+c
In[2]:= poly[k_] = Simplify[SeriesCoefficient[Exp[s[x]], {x, 0, k}], k>0]
Out[2]= DifferenceRoot[Function[{y,n},
       {-2 a y[n] - b y[1+n] + (2+n) y[2+n]==0, y[0]==E^c,  y[1]==b E^c} ]]
The above shows the difference equation (recurrence relation) and the initial conditions that the polynomials must satisfy for any given quadratic s[x]. We can now use the recurrence relation to calculate the sequence. Below we compare calculating using poly[n] (the DifferenceRoot object) and Recurrence table
Code:
In[11]:= dr = Table[poly[n], {n, 0, 20}]; // Timing
         drExp = Expand[dr]; // Timing
Out[11]= {0.21, Null}
Out[12]= {1.57, Null}
In[13]:= rt = RecurrenceTable[{-2 a y[n] - b y[1 + n] + (2 + n) y[2 + n] == 0,
               y[0] == E^c, y[1] == b E^c}, y, {n, 0, 20}]; // Timing
         rtExp = Expand[rt]; // Timing
Out[13]= {0.01, Null}
Out[14]= {1.66, Null}
In[15]:= dr == rt
Out[15]= True
In[16]:= drExp == rtExp
Out[16]= True
The problem is that both evaluating the DifferenceRoot poly[k] and using RecurrenceTable, whilst great for purely numeric functions, are horrible for symbolic functions such as the one above. the reason for this is that they don't simplify y[n] after every step and end up with a terrible mess, e.g.
Code:
In[17]:= dr[[6]]
         drExp[[6]]
Out[17]= 1/5 (2/3 a (2 a b E^c+1/2 b (2 a E^c+b^2 E^c))+1/4 b (a (2 a E^c+b^2 E^c)+1/3 b (2 a b E^c+1/2 b (2 a E^c+b^2 E^c))))
Out[18]= 1/2 a^2 b E^c+1/6 a b^3 E^c+(b^5 E^c)/120
Finally, compare calculating by taking derivatives with calculating using http://reference.wolfram.com/mathematica/tutorial/FunctionsThatRememberValuesTheyHaveFound.html" (in the latter, it's the Expand that makes the difference compared to the DifferenceRoot and RecurrenceTable options given above)
Code:
In[25]:= deriv=Table[1/k! D[Exp[s[x]], {x,k}] /. x->0, {k, 0, 100}]//Expand;//Timing
Out[25]= {0.36, Null}
In[26]:= Clear[y]
         y[n_Integer?Positive] := y[n] = 1/n (2 a y[-2+n] + b y[-1+n]) //Expand
         y[0] = E^c;
         y[1] = b E^c;
In[30]:= mem = Table[y[n], {n, 0, 100}]//Expand;//Timing
Out[30]= {0.3, Null}
In[31]:= deriv==mem
Out[31]= True
Also, if you want the recurrence relation for the polynomials not evaluated at x=0, try
Code:
s[x_] := a x^2 + b x + c
poly[k_] = Simplify[SeriesCoefficient[Exp[s[x]], {x, x, k}], k > 0]
which returns
Code:
   {-2 a y[n] - (b + 2 a x) y[1+n] + (2+n) y[2+n]==0,
   y[0]==E^(c+b x+a x^2),  y[1]==(b+2 a x) E^(c+b x+a x^2)}
   ]][k]
I must have had my brain turned off this morning, since I didn't mention that what you supplied was an exponential generating function. Just google "generating function recursion relation" to find stuff on how to approach these problems more generally. In particular the free book "generatingfunctionology" is worth reading (not that I can remember much of it)
Thanks a lot for the answers!
Your hint about generating functions was also very useful. I hadn't thought about that!
