Using Jordan Curve Thm to Show H_n(R^n) Trivial?
  • Context: Graduate
  • Thread starter Thread starter WWGD
    Curve
The discussion revolves around the application of the Jordan Curve Theorem (JCT) to demonstrate the triviality of the homology groups H_n(R^n) and the homotopy groups Pi_n(R^n). Participants explore the implications of the theorem in the context of cycles and boundaries in R^n, examining whether all n-cycles can be represented as images of spheres.
  • One participant suggests that the JCT can be used to show that H_n(R^n) is trivial, arguing that cycles in R^n can be seen as images of spheres that bound regions.
  • Another participant counters that using the JCT complicates the argument, stating that all homology groups of R^n greater than zero are trivial due to its contractibility and the properties of homotopy equivalence.
  • A participant expresses interest in whether all n-cycles can be represented as images of spheres and questions the implications of the JCT regarding the bounding of cycles.
  • One participant argues that not all cycles can be represented as images of spheres, providing the example of the boundary of two disjoint n+1-simplices, which is not connected.
  • Another participant suggests that cycles could be viewed as unions of continuous images of S^n, potentially addressing the previous objection.
  • A participant raises uncertainty about the geometric definition of a cycle, noting that it may depend on the choice of homology theory, which are generally equivalent.
  • One participant points out that an example provided earlier (Alexander's horned sphere) illustrates a cycle that is not the image of S^n.
  • Another participant emphasizes the need to check the dimensions involved in the JCT and argues that maps from spheres are a specific case rather than a generalization.
  • A participant expresses interest in a proof of the generalized JCT that does not rely on the homology of the sphere or Euclidean space.
Participants exhibit disagreement regarding the use of the JCT to demonstrate the triviality of homology groups and the representation of cycles as images of spheres. Multiple competing views remain, and the discussion is unresolved.
Participants note limitations regarding the definitions of cycles and the implications of the JCT, as well as the potential for circular reasoning in proofs related to the theorem.
WWGD
Hi, All:
I hope I am not missing something obvious: can't we use the Jordan Curve Thm. to show
that the homology H_n(R^n) of R^n is trivial ? How about showing that Pi_n(R^n) is trivial?
It seems like the def. of cycles in a space X is geenralized by continuous , injective maps f: S^n -->X . When X=R^n, JCT says that f(S^n) separates R^n into 2 regions, which can be seen as saying that f(S^n) bounds, so that every cycle bounds, and then the homology is trivial.
Using the generalized Jordan curve theorem is massively overcomplicating it. All the homology groups of R^n greater than the zeroth are trivial, because R^n is contractible and homology groups remain unchanged under homotopy equivalence. Likewise with the homotopy groups.
I understand; I know R^n is contractible, and we can use homotopy equivalence, etc., but I am trying to see if all n-cycles can be represented as images of spheres, and if the JCT actually says that these cycles bound, i.e., the interior region into which the simple-closed curve separates R^n, is the(an) object being bounded.
Well, obviously not all cycles can be represented as the image of a sphere. Just take the boundary of two disjoint n+1-simplices in the space -- that boundary is not even connected, hence cannot be the image of a sphere.
As for the other question -- yes, the image of the sphere is always the boundary of the inside, but the inside is not always homeomorphic to a ball. To see this, consider an Alexander horned sphere with the origin on the inside. The outside is not simply connected, but the inside is. Now consider the image of the horned sphere under the map v ↦ v/|v|². This exchanges the inside and the outside, so now the inside is not simply connected and hence is not homeomorphic to a ball.
But it seems like you could do away with the first objection by saying that a cycle is the
union of continuous images of S^n .
I guess I am unclear about the geometric definition of a cycle; I guess this would
depend on the choice of homology we make, but, given that these theories are all
equivalent ( i.e., they output isomorphic groups for the same space), the choice should
be independent of choice of homology.
I think Citan just gave an example of a cycle that is not the image of S^n with
Alexander's horned sphere, as a space that is bound by a 2-dimensional object
that is not the image of a sphere.
And, with respect to cycles, I would say that , in the most general sense, an n- cycle would
be an n-dimensional subspace that can be oriented (if the subspace is triangulable and can be made into a simplicial complex, then the net boundary should be zero); maybe others here can double-check.
First, check the dimensions on the jordan curve theorem. Second, maps from the sphere are most definitely not a generalization, since they're a very special case of maps from the n-simplex.
Third, I'd be interested in seeing a proof of the generalized Jordan curve theorem for continuous maps that doesn't render this circular: I.e. Showing that it separates without knowing anything about the homology of the sphere or Euclidean space.
  • · Replies 0 ·
  • · Replies 69 ·
9K
  • · Replies 80 ·
11K
  • · Replies 86 ·
14K
  • · Replies 25 ·
