Analysis of Variance: Is Toy Color a Factor?
  • Context: Graduate
  • Thread starter Thread starter Rasalhague
    Analysis Variance
The discussion centers on the application of Analysis of Variance (ANOVA) to determine if toy color influences the duration of play among children. The null hypothesis states that the means of playtime for different toy colors are equal, while the alternative hypothesis posits that at least one mean is different. For a significance level of 1%, the critical F-value is established at 4.38, derived from the degrees of freedom of 3 and 36. The F-test for ANOVA is confirmed to be one-tailed, focusing on whether the variance of population means exceeds the mean of population variances.
  • Understanding of null and alternative hypotheses in statistical testing
  • Familiarity with ANOVA and F-tests
  • Knowledge of significance levels and critical values
  • Proficiency in using Excel functions such as F.INV.RT
  • Study the application of ANOVA in different contexts, focusing on toy color and playtime
  • Learn about the assumptions underlying ANOVA, including normality and equal variances
  • Explore the differences between one-tailed and two-tailed tests in hypothesis testing
  • Investigate the use of Excel for statistical analysis, particularly F-tests and ANOVA
Statisticians, researchers in child development, educators, and anyone interested in the statistical analysis of behavioral studies.
Rasalhague
Well, just as I thought I'd got the hang of this...
A researcher believes that the color of a toy will affect how long children will play with it [...] her null hypothesis is that [itex]\mu_1 = \mu_2 = \mu_3 = \mu_4[/itex]. The alternative is that not all the means are equal; that is, that the color of the toy does make a difference.
For a 1% significance level, the critical region is F > or = 4.38.
Koosis: Statistics: A Self-Teaching Guide, 4th ed., §§ 6.29-43.
The "degreeses of freedom" are 3 and 36. This critical value, 4.38, is found by looking up the score for 1% in the table at the back of the book, or in Excel with F.INV.RT(0.01,3,36) = 4.38.
But this is a two-tailed test, right? So why do we not divide the desired significance level by 2 before inputting it into this function, as was explained by Koosis in §§ 6.19-22, and on this page? Thus: F.INV.RT(0.01/2,3,36) = 5.06. This latter method makes sense because, in a two-tailed test a result could achieve significance by being far enough from the mean of the F distribution on either side, so extreme results on one side of the mean will only constitute half of that 1%.
Koosis concludes that the result, which is 4.42, is significant, since it's greater than 4.38. But I'd have concluded that it's not significance, since it's less than 5.06.
Ah, here we go:
http://www.le.ac.uk/bl/gat/virtualfc/Stats/variance.html
If I've (half) understood this right, an F-test for ANOVA is always 1-tailed because what the F-test is directly testing is the alternative hypothesis that the variance of population means is greater than the mean of population variances.
If it is greater, one concludes that the population means are not equal. But this is an indirect consequence, an inference from a test of variances.
The objects that play the same role as the two population variances in the other kind of F-test - the kind of F-test used simply to test variances - are being used in the ANOVA test in the manner of a 1-tailed test; we're asking specifically whether the numerator is greater than the denominator, not merely whether they're unequal.
Hello, Yesterday Rasalhague! There's a problem with this rationalization. When you get to § 6.73, you'll find it says ANOVA and the t test for the difference of two means depend on the same assumptions, namely that the population distributions are normal, and that the population variances are equal.
What's being tested is whether there's a difference between the variance of the group means (approximated by the numerator: the between-groups variance estimate) and the mean of the variances of the groups (approxmated by the denominator: the within-groups variance estimate). And one only considers the result significant if the numerator is greater than the denominator.
  • · Replies 33 ·
