Find the total hydrostatic force on the face of a semi-circular dam
The total hydrostatic force on the face of a semi-circular dam with a radius of 20 m can be calculated using the integral F = 19600 * integral[0,20] (20-y)sqrt(400-y^2)dy, where 19600 is derived from the product of water density (1000 kg/m³) and gravity (9.8 m/s²) multiplied by 2. An alternative approach presented in the discussion uses the integral F = integral[0,20] 9800sqrt(400-h^2)2h dh, which simplifies the evaluation by focusing on depth h instead of (20-y). Both methods yield similar results, but the latter is more straightforward for evaluation.
  • Understanding of hydrostatic pressure principles
  • Knowledge of calculus, specifically integration techniques
  • Familiarity with the geometry of semi-circular shapes
  • Basic physics concepts related to density and gravity
  • Learn advanced integration techniques, including trigonometric substitution
  • Study hydrostatic force calculations in various geometrical contexts
  • Explore the application of calculus in fluid mechanics
  • Review the principles of pressure distribution in fluids
Students in engineering or physics courses, particularly those studying fluid mechanics and hydrostatics, as well as professionals involved in civil engineering and dam design.
GreenPrint
Find the total hydrostatic force on the face of a semi-circular dam with radius of 20 m, when its reservoir is full of water. The diameter of the semicircle is the top of the dam.
the width at any point would be 2sqrt(400-y^2) from x^2+y^2 = r^2
the density would be 1000 kg/m^3, this is the rough estimate for the density of water I am told to use in the class
gravity is 9.8 m/s^2, for some reason we don't use 9.81 in the class
I got F= 19600*integral[0,20] (20-y)sqrt(400-y^2)dy
were 19600 is just density times gravity times 2 = 1000*9.8*2
20-y is the depth at any given point y
I have no idea how to evaluate the indefinite integral
integral (20-y)sqrt(400-y^2)dy
when I tried doing so I spent a good amount of time trying to evaluate it using a trig sub but ended up doing something terribly wrong for some reason I got
integral (20-y)sqrt(400-y^2)dy = (ysqrt(400-y^2))/40 - 10 cos^(-1)(y/20) + sqrt(400-y^2)/3 - (y^2 sqrt(400-y^2))/1200 + c
I got frustrated with it and just plugged into my calculator
and got about 70883765.35 N
This question however has reappeared on a practice test in which the problem was solved differently but I think it may have been solved wrong, the answer key my professor made had
as the integral to be evaluated were they just used h for the depth instead of (20-h). I thought you had to include this though in the integral and not just h because you want the depth at any point of any of the horizontal slices and not just h
So I thought that the problem was solved wrong on the answer key but sense my integral I had a really tough time evaluating by hand 19600*integral[0,20] (20-y)sqrt(400-y^2)dy I think I may have done something wrong and I was just suppose to use y instead of (20-y).
What's the correct integral to solve this problem? Thanks for any help!
I get the same integral as your professor.
I worked it out in terms of depth, so if P(h) is the pressure as a function of depth:
P(h) = gdh [g=gravity, d=density, h=depth].
If w(h) is the width of the dam as a function of depth, then
w(h) = 2(r^2 -h^2)^(1/2) [r=radius of the semi-circle]
The force on a region of the dam, dh is pressure times area, so
dF = P(h)w(d)dh
so
F = [itex]\int_0^r P(h)w(d)dh[/itex]
or
F = [itex]\int_0^r (9.8)(1000)(h)(2)(400-h^2)^{1/2}dh[/itex]
