| New Reply |
What causes blackbody radiation |
Share Thread | Thread Tools |
| Aug17-11, 04:46 AM | #1 |
I've seen the cavity resonator model but no one has been able to explain to me what the underlying physical mechanism is that generates the blackbody radiation continuum. Is there some intuitive explanation or is it deeply rooted in quantum mechanics?
An explanation i've heard is that it's doppler shifted collisional de-excitation, is this true? |
| PhysOrg.com |
physics news on PhysOrg.com >> Promising doped zirconia >> New X-ray method shows how frog embryos could help thwart disease >> Bringing life into focus |
| Aug17-11, 02:09 PM | #2 |
Hot things glow. Objects with non-zero temperature have their constituent charged particles in continuous thermal, random motion. The acceleration of charged particles in this motion leads to electromagnetic radiation (acceleration of charged particles always leads to electromagnetic radiation). You don't need quantum theory to predict that hot things glow (with a continuous spectrum). You need it to avoid the ultraviolet catastrophe.
| Aug17-11, 03:58 PM | #3 |
So essentially it arises from Brem within atoms and molecules? What degree of freedom do the charges have? Is it typically a dipole vibration within a molecule, or some kind of orbital vibration in atoms?
A side question; Someone once mentioned to me that painting an object black increases the amount of radiation that object will emit. I didn't understand the blackbody process so I couldn't really comment, but now I'm having a hard time imagining how a pigment could alter the amount of brem radiation emitted by thermally agitating charges. I figure the colour of a surface is either determined by absorption lines, or some kind of surface diffraction process, is this the case, and if so how can such surface properties mediate the amount of energy lost from that surface through radiation? |
| Aug17-11, 04:11 PM | #4 |
Well, lets assume that the body is much hotter than its surroundings, so it's painted black specifically for the purpose of dissipating heat, and the amount of heat absorbed is negligible compared to the amount dissipated.
The context is that an air force pilot once told me that the SR-71 was painted black not only for stealth reasons, but also to facilitate heat removal from the skin (which is heated considerably at supersonic speeds). This shouldn't really have much to do with absorption. Sorry, lazy shorthand. "brem" is "bremsstrahlung radiation" |
| Aug17-11, 04:15 PM | #5 |
That last post was a reply to a deleted post
| Aug17-11, 06:11 PM | #6 |
I don't believe the color of an object has that much to do with how much radiation it emits at a given temperature, if it has an effect at all.
| Aug17-11, 07:29 PM | #7 |
If you were to desing a system without continuous spectrum, it (color) wouldn't matter then. |
| Aug17-11, 07:55 PM | #8 |
| Aug17-11, 07:55 PM | #9 |
Edit: I don't have the data right now but I remember there was a small but noticeable difference, not as big as the polished vs non polished surfaces. |
| Aug17-11, 08:00 PM | #10 |
Ok, I did find this: http://en.wikipedia.org/wiki/Emissivity
So not all objects emit radiation equally. |
| Aug17-11, 10:52 PM | #11 |
Here's my attempt at explaining it. Imagine an object that is painted white. That means if you shine light on it, the light will reflect off it. Now imagine all the atoms inside the object jiggling. If those atoms emit light, then when they encounter the surface, they will reflect inwards. So the object reflects light coming from both the outside and the inside, and hence is both a poor absorber and emitter of radiation in the visible spectrum (i.e., visible light). An object whose surface is painted white will not emit light because that light is trapped inside the object due to the surface. |
| Aug17-11, 11:31 PM | #12 |
| Aug17-11, 11:37 PM | #13 |
Another simple example. Noticed this with a teflon frying pan. Warm the pan on the stove. Hold it up in front of your face(like a hand mirror) and you'll notice a dramatic difference in the heat you feel on your face as you flip the pan between dark inner coating and light metallic back.
| Aug18-11, 12:07 AM | #14 |
There are other factors as well, but they extent beyond the topic of this discussion. |
| Aug18-11, 12:15 AM | #15 |
| Aug18-11, 12:59 AM | #16 |
I think the differences in emission with respect to the objects color depends on the object not being a blackbody, which is what the topic is about. It seems like arguing that an ice rink is not really a friction-less surface, which is true but misses the point.
| Aug19-11, 12:31 AM | #17 |
Regardless, it would be nice to know why and how colour affects the emissitivity of a body.
| New Reply |
| Thread Tools | |
Similar Threads for: What causes blackbody radiation
| Blackbody radiation | Introductory Physics Homework | 3 | ||
| Blackbody radiation | Quantum Physics | 4 | ||
| about the radiation of blackbody | Quantum Physics | 4 | ||
| blackbody radiation | Introductory Physics Homework | 3 | ||
| Need help with blackbody radiation | Introductory Physics Homework | 2 | ||
