Solving Blocks and Springs on a 15m Ledge: Energy, Velocity, Distance
  • Thread starter Thread starter Soaring Crane
    Blocks Springs
The discussion focuses on a physics problem involving a spring and a block on a 15-meter ledge. The block, weighing 3 kg and compressed by a spring with a constant of 15 N/m, is analyzed for its energy states and motion after falling. Key calculations include the initial elastic potential energy of 1.875 J, gravitational potential energy of 75 J, and the block's velocity before impact at 2.7 m/s. The distance rolled from the base of the ledge is determined to be 4.7 m.
  • Understanding of elastic potential energy calculations using the formula kx²/2
  • Knowledge of gravitational potential energy and the formula mgh
  • Basic principles of kinematics related to free fall
  • Familiarity with energy conservation concepts in physics
  • Study the derivation and application of the spring constant in various scenarios
  • Explore kinematic equations for objects in free fall
  • Investigate energy conservation principles in mechanical systems
  • Learn about the effects of friction on rolling motion
Students in physics, educators teaching mechanics, and anyone interested in solving problems related to energy, motion, and spring dynamics.
Soaring Crane
There is a spring on a ledge that is 15 m above the ground. It is compressed 0.5 m by a block of 3 kg, and its spring constant is 15 N/m. I'm not certain of the exact wording, but somehow the compressed string (with the block) is the horizontal length of the ledge.
Now in this scenario, the block as a result of the spring falls from the ledge "vertically" to the ground and then rolls a distance D from the base of the ledge.
a. Find the initial elastic potential energy.
b. Find the initial gravitational potential energy of the block.
c. Find the gravitational potential energy of the block as it hits the ground.
d. Find the block's velocity before hitting the ground.
e. Find D.
Diagram:
/\/\/\/\|_|
________|
________|
________|15 m
________|_______D_______
/\/\spring
|__|block
Any hints or pointers, aside from general formulas like kx^2/2 and and mgh, are appreciated.
You're going to have to show us what you did. It's hard to pick out where you are having trouble if we don't know what you did. Part (a) looks like you just have to take the numbers you are given and plug them into a formula.
a. 1.875 J
b. 75 J
c. 0 J
d. 2.7 m/s
e. 4.7 m
