How Can I DIY a Safe Pressurized Water Tank for Testing Waterproof Watches?
  • Thread starter Thread starter kateman
    Tank
The discussion centers around the DIY construction of a safe pressurized water tank for testing the waterproof capabilities of watches. Participants explore various methods and materials for achieving this, focusing on safety and practicality in a home setting.
  • Experimental/applied
  • One participant suggests using a tall cylinder as a basic structure for the tank but seeks advice on machinery to boost pressure safely.
  • Another participant humorously points out that using water can be simplified by noting that 1 inch of mercury equals 13 inches of water, implying that a smaller tank could simulate greater depths.
  • A practical suggestion involves using a sturdy jar with a pressure gauge, filling it with a carbonated beverage, and shaking it to test for leaks while monitoring the pressure gauge.
  • Another idea proposes utilizing household water pressure, which is typically around 50 psi, and recommends using PVC materials rated for pressure from a hardware store.
  • A participant expresses appreciation for the ideas but notes that local water pressure has been reduced due to drought conditions in their area, which may affect their ability to implement some suggestions.
Participants present multiple competing ideas and methods without reaching a consensus on the best approach. The discussion remains unresolved regarding the most effective and safe method for constructing the pressurized tank.
Participants mention various assumptions, such as the availability of materials and local water pressure conditions, which may affect the feasibility of their proposed methods.
kateman
Hi everyone, lately I have been wondering how I could make a pressurized tank to test how waterproof my watch is - I am not keen to pressurize air, I figure it would be safer doing it with water. Any idea how you could do this DIY style at home?
The best I could come up with is a tall cylinder, but I was interested about machinery I could use to help boost the pressure inside a safe material - anyone out there tried doing this or something similar?
LOL, terrible suggestion here:
1 inch depth of mercury = 13 inches depth of water.
You can compactify your research by a factor of 13, so your tank requirement is much easier. You can simulate a depth of almost 100 feet in your 8 foot high living room without a pressure pump.
Here is a little more practical idea:
drill a hole in a lid from a sturdy jar. install pressure gauge.
put watch in sturdy jar, fill jar with your favorite clear carbonated beverage.
seal jar.
shake, and watch pressure gauge and watch for leakage.
(wear goggles!)
The water pressure in your pipes must be at least 50 psi, there's your pressure source. For the container, get some PVC from a hardware store (rated for pressure).
thanks Tasp77 and Q_Goest - interesting ideas. I like the idea of carbonation, and of the tap water pressure, but here in Australia we've just come out of a drought and the pressure in our taps has been reduced where I live to save water.
Cheers!
  • · Replies 17 ·
  • · Replies 56 ·
  • · Replies 17 ·
