Why do inductors and capacitors have voltage-current lead/lag?
  • Context: Undergrad
  • Thread starter Thread starter brendan_foo
Inductors cause voltage to lead current by 90 degrees, while capacitors result in current lagging voltage by 90 degrees. This behavior is due to the physical properties of these components; in inductors, voltage must overcome the inertia of electrons, whereas in capacitors, current accumulates charge on plates before voltage develops. Capacitor reactance decreases at higher frequencies because the rapid change in current flow encounters less opposition, as electrons vibrate over shorter distances in the dielectric material.
  • Understanding of AC circuit theory
  • Familiarity with reactance concepts in electrical engineering
  • Basic knowledge of inductors and capacitors
  • Experience with mathematical derivations in electrical systems
  • Research the mathematical derivation of reactance in capacitors and inductors
  • Explore the concept of impedance in AC circuits
  • Learn about the role of dielectric materials in capacitors
  • Investigate the effects of frequency on circuit behavior
Electrical engineers, physics students, and anyone interested in understanding the behavior of inductors and capacitors in AC circuits.
brendan_foo
Hi there... I know that in an inductor, its voltage will lead the current by 90 degrees and for a capacitor it wil lag the current by 90 degrees. I have seen the mathematical derivation for this too , but I can't get my head around what is actually physically happening here.
Why is the reactance of a capacitor less at greater frequencies? Whats happening with relation to the charges on the plates etc.. please someone help me, what is 'physically going on', as the mathematical derivation simply isn't enough for my curiousity...
Thanks all :smile:
Regards
Brendan ;)
You can think of it like in an inductor the voltage (pressure) must come first to overcome the inertia of the electrons in the wire; in a capacitor the current must first pile up electorns on the plates for voltage to develop across them.
Reactance in a capacitor is less at higher frequencies because it is the change in current flow that is felt and higher frequencies mean faster change.
brendan_foo said:
...Why is the reactance of a capacitor less at greater frequencies?...
The dielectric is an insulator, so the outer-shell electrons are bound to their atoms. They can't jump from one atom to another, as is the case with a conductor. So the current that flows in the dialectric is due to the electrons vibrating back and forth. They encounter less oposition if they vibrate over a short distance, than a long one, which is the case of a high frequency compared to a low one.
14K
  • · Replies 61 ·
  • · Replies 33 ·
