Mathematica not supporting graphs code is as
  • Context: Mathematica
  • Thread starter Thread starter adnan jahan
    Code Graphs Mathematica
The discussion revolves around issues encountered while attempting to plot a graph in Mathematica, particularly related to the complexity of the code and the definitions of variables. Participants explore potential reasons for the failure to generate the graph and offer troubleshooting advice.
  • One participant expresses difficulty in plotting a graph in Mathematica due to the appearance of imaginary numbers in the code.
  • Another participant points out that the variable "u" is not defined, suggesting that the issue may stem from this oversight.
  • There is a discussion about the complexity of the code, with some participants suggesting that it may be too complicated for Mathematica to handle effectively.
  • Several participants emphasize the importance of breaking down the code into simpler parts for easier debugging.
  • One participant mentions having successfully plotted a complex number in a previous research paper, indicating that the current issue is unexpected.
  • Another participant provides specific advice on correcting the use of the exponential function in Mathematica, highlighting the need for proper syntax.
  • A later reply indicates that the participant successfully generated the graph after receiving support from others.
  • Another participant shifts the topic to a new question about solving a system of linear equations using Mathematica.
Participants generally agree that the complexity of the code may be a contributing factor to the issues faced, and there is a consensus on the need to simplify and test the code incrementally. However, there is no clear resolution regarding the specific cause of the initial problem.
Some participants note that Mathematica is case sensitive, which may lead to errors if variable names are not used consistently. Additionally, there are unresolved questions about the definitions and substitutions used in the code.
adnan jahan
mathematica not supporting graphs,,,code is as
Dear Fellow I was trying to make graph using mathematica but because of imaginary appearing mathematica is not supporting don't now how to evaluate the graph,,where code for mathematica is as
rho = 1.74*10^(3);
lambda = 9.4*10^(11);
mue = 4.0*10^(11);
T0 = 293;
k = 0.6*10^(-2);
K = 1*10^(11);
K1 = 0.3*10^(-3);
CE = 383.1;
gamma = 0.779*10^(-8);
gamma1 = 0.1*10^(-5);
gamma11 = 0.5*10^(-3);
j = 0.2*10^(-21);
alpha0 = 0.779*10^(-4);
lambda0 = 0.5*10^(11);
lambda1 = 0.2*10^(11);
umega = 2;
t = 0.1;
aphat = 1.78*10^(-5);
f = 0.5;
p = 10;
b = 2;
w0 = -2;
xi = 1;
z = 0.1;
w = w0 + xi;
c2 = mue/rho;
c3 = (2*alpha0)/(3*rho*j);
c4 = (2*lambda1)/(9*rho*j);
c5 = (2*lambda0)/(9*rho*j);
c6 = (2*gamma11)/(9*rho*j);
w1 = (rho*CE*c2)/K1;
epsilon1 = ((gamma1^2)*T0)/(rho^2*CE*c2);
epsilon2 = K1/(rho*CE*c2);
epsilon3 = (K*w1)/(rho*CE*c2);
epsilon4 = (gamma1*gamma11*T0)/(rho^2*CE*w1*c2);
epsilon = epsilon2 + epsilon3*w;
c1 = (lambda + 2*mue + k)/rho;
a0 = (c2)/(c1);
a1 = lambda0/(lambda + 2*mue + k);
a2 = (rho*c2)/(mue + k);
a3 = k/(mue + k);
a4 = (k*c2)/(gamma*w1^2);
a5 = (rho*j*c2)/gamma;
a6 = (c3)/(c2);
a7 = (c4)/(w1^2);
a8 = (c5)/(w1^2);
a9 = (2*gamma11*c2)/(9*gamma1*j*w1^2);
A1 = b^2 + a0*(w^2 - umega^2);
A2 = 2*umega*a0*w;
A3 = b^2 + a2*(w^2 - umega^2);
A4 = 2*umega*a2*w;
A5 = b^2 + 2*a4 + a5*w^2;
A6 = b^2*a6 + a7 + w^2;
g1 = epsilon4*w - a1*epsilon1*w^2;
g2 = -epsilon4*w*A1 + a1*epsilon1*w^2*b^2;
g3 = a1*epsilon*b^2 + a1*w^2 + a0*epsilon4*w;
g4 = A2*epsilon4*w;
g5 = A3 + A5 - a3*a4;
g6 = A3*A5 - a3*a4*b^2;
g7 = g2 - g1*g5;
g8 = -g2*g5 + g1*g6 + g4*A4;
g9 = g2*g6 - g4*A4*A5;
g10 = -g3 - a1*epsilon*g5;
g11 = g3*g5 + a1*epsilon*g6;
g12 = g3*g6;
g13 = a6*(epsilon*b^2 + w^2) + A6*epsilon;
g14 = epsilon4*a9*w + A6*(epsilon*b^2 + w^2);
g15 = epsilon1*a6*w^2*b^2 + A6*epsilon1*w^2 - a8*epsilon4*w;
g16 = epsilon4*a8*w*b^2 - epsilon1*w^2*A6*b^2;
g17 = epsilon*(a6*g1 + a1*epsilon1*w^2*a6);
g18 = -a6*(epsilon*g7 + epsilon1*w^2*g10) + g13*g1 + a1*epsilon*g15;
g19 = a6*(epsilon*g8 + epsilon1*w^2*g11) - g13*g7 + g14*g1 -
a1*epsilon*g16 - g10*g15;
g20 = -a6*epsilon*g9 + g13*g8 - g14*g7 + g10*g16 + g11*g15 +
g12*a6*epsilon1*w^2;
g21 = -g13*g9 + g14*g8 - g11*g16 + g12*g15;
g22 = -g14*g9 - g12*g16;
a10 = lambda_ 0/(rho*c2);
a11 = c1/c2;
a12 = lambda/(rho*c2);
a13 = (mue + k)/(rho*c2);
a14 = (k)/(rho*c2);
a15 = (gamma*w1^2)/(rho*c2^4);
a16 = (alpha_ 0*w1)/(rho*c2^(3/2));
k1 = +0.0024
k2 = +0.0018 - 0.0015*I
k3 = 0.0018 + 0.0015*I
k4 = 0.0003 + 0.0019*I
k5 = 0.0003 - 0.0019*I
H21 = (A4*(k1^2 - A5))/(k1^4 - k1^2*g5 + g6);
H22 = (A4*(k2^2 - A5))/(k2^4 - k2^2*g5 + g6);
H23 = (A4*(k3^2 - A5))/(k3^4 - k3^2*g5 + g6);
H24 = (A4*(k4^2 - A5))/(k4^4 - k4^2*g5 + g6);
H25 = (A4*(k5^2 - A5))/(k5^4 - k5^2*g5 + g6);
H11 = (k1^4*a6*epsilon1*w^2 - k1^2*g15 - g16)/(k1^4*a6*epsilon -
k1^2*g13 + g14);
H12 = (k2^4*a6*epsilon1*w^2 - k2^2*g15 - g16)/(k2^4*a6*epsilon -
k2^2*g13 + g14);
H13 = (k3^4*a6*epsilon1*w^2 - k3^2*g15 - g16)/(k3^4*a6*epsilon -
k3^2*g13 + g14);
H14 = (k4^4*a6*epsilon1*w^2 - k4^2*g15 - g16)/(k4^4*a6*epsilon -
k4^2*g13 + g14);
H15 = (k5^4*a6*epsilon1*w^2 - k5^2*g15 - g16)/(k5^4*a6*epsilon -
k5^2*g13 + g14);
H31 = -((a4*A4*(k1^2 - b^2))/(k1^4 - k1^2*g5 + g6));
H32 = -((a4*A4*(k2^2 - b^2))/(k2^4 - k2^2*g5 + g6));
H33 = -((a4*A4*(k3^2 - b^2))/(k3^4 - k3^2*g5 + g6));
H34 = -((a4*A4*(k4^2 - b^2))/(k4^4 - k4^2*g5 + g6));
H35 = -((a4*A4*(k5^2 - b^2))/(k5^4 - k5^2*g5 + g6));
H41 = (a8*(k1^6 - b^2) - a9*H11)/(a6*k1^2 - A6);
H42 = (a8*(k2^6 - b^2) - a9*H12)/(a6*k2^2 - A6);
H43 = (a8*(k3^6 - b^2) - a9*H13)/(a6*k3^2 - A6);
H44 = (a8*(k4^6 - b^2) - a9*H14)/(a6*k4^2 - A6);
H45 = (a8*(k5^6 - b^2) - a9*H15)/(a6*k5^2 - A6);
H61 = a10*H41 - k1*a11*(-k1 + I*b*H21) + I*b*a12*(I*b + k1*H21) - H11;
H62 = a10*H42 - k2*a11*(-k2 + I*b*H22) + I*b*a12*(I*b + k2*H22) - H12;
H63 = a10*H43 - k3*a11*(-k3 + I*b*H23) + I*b*a12*(I*b + k3*H23) - H13;
H64 = a10*H44 - k4*a11*(-k4 + I*b*H24) + I*b*a12*(I*b + k4*H24) - H14;
H65 = a10*H45 - k5*a11*(-k5 + I*b*H25) + I*b*a12*(I*b + k5*H25) - H15;
H71 = I*b*(I*b*H21 - k1) - k1*a13*(I*b + H21*k1) + a14*H31;
H72 = I*b*(I*b*H22 - k2) - k2*a13*(I*b + H22*k2) + a14*H32;
H73 = I*b*(I*b*H23 - k3) - k3*a13*(I*b + H21*k3) + a14*H33;
H74 = I*b*(I*b*H24 - k4) - k4*a13*(I*b + H24*k4) + a14*H34;
H75 = I*b*(I*b*H25 - k5) - k5*a13*(I*b + H25*k5) + a14*H35;
M1 = 8.9842 10^045 + 6.2942 10^(046) I
M2 = 6.9622 10^046 - 5.3668 10^(046) I
M3 = 2.1724 10^046 + 3.7184 10^(046) I
M4 = -9.1931*10^046 + 7.5101 10^(046) I
M5 = -8.3987*10^045 - 1.2156 10^(047) I
U1 = (-k1 + I*b*H21)*M1*e^(-k1*x) + (-k2 + I*b*H22)*M2*
e^(-k2*x) + (-k3 + I*b*H23)*M3*e^(-k3*x) + (-k4 + I*b*H24)*M4*
e^(-k4*x) + (-k5 + I*b*H25)*M5*e^(-k5*x);
U = U1*e^(w*t + I*b*z);
Plot[Re, {x, 0, 5}],
any support in which I can find graph will be appreciated
Have you defined u? I see where you defined U, but not u.
FYI, this is a horrible mess. You need to start with something simple and gradually build up to something complicated.
yes, U=U1 * e^(w*t+Ibz),
basically i did it on MATLAB and found graph now converted the code related to mathematica because want to confirm it,,,,but mathematica is not supporting
Yes, I saw that U was defined, but I never saw where u was defined. You are plotting u, not U. Remember, Mathematica is case sensitive. It is not Mathematica's fault that you are asking it to plot something you haven't defined.
oopps sory ,,that is "U" not "u"
Then there is a problem in your definition of U. For example:
Plot[Re[Exp[-I x]], {x, 0, 5}]
plots fine. So there is not a problem with Plot.
In code it is U,,, and U is still not working
Is it possible that mathematica is not plotting because the complexity level is high??
Yes U is very messy, I am not surprised it is not working. The problem is your definition of U, not a problem with Plot.
If you evaluate
U /. x->1
do you get what you expect?
I doubt it. Much more likely you did not correctly define U because the complexity level is high. You should break your code down into smaller chunks and test each chunk to make sure that it is correct at each step. What you have written is a mess.
yap it is making graph of simple complex ,,,,and even in my last research paper I have plotted for a complex number but this is not working ...
I will make the code bit simple by using mathematica symbls then I will chk what results are,,,
and I will reply after confirming that,,, thanku so much for your support "DALESPAM"
Welcome, sorry I cannot help you troubleshoot U other than general advice to break things up and test each small piece.
e is not the same as e^1 in Mathematica. You need to either specify E or Esc e e Esc. That's one problem, also the way you defined u, you need to make the substitution U/.x->myvariable. So try changing the last part to:
Code:
U1 = (-k1 + I*b*H21)*M1*E^(-k1*x) + (-k2 + I*b*H22)*M2*
    E^(-k2*x) + (-k3 + I*b*H23)*M3*E^(-k3*x) + (-k4 + I*b*H24)*M4*
    E^(-k4*x) + (-k5 + I*b*H25)*M5*E^(-k5*x);
U = U1*E^(w*t + I*b*z);
Plot[Re[U /. x -> x], {x, 1, 5}]
Dear Fellows by your support and encouragement I successfully draw the graph in mathematica,,,If corrected form is required then do contact,
Thanks to all of you
How I can find solution of system of linear equation using mathematica??
as,35x1+45x2+90x3=-2
5x1+6x2-3x3=0
10x1+12x2+15x3=5
need to find the values of x1,x2 and x3 using mathematica
