Mean, and standard deviation question.
The discussion focuses on calculating the mean, standard deviation, and coefficient of variation for uniaxial strain defined by the equation e = d/l, where d ~ N(0.0015, 0.000092) and l ~ N(2.0000, 0.0081). The mean strain is calculated as X_e = 0.00075, while the standard deviation was initially miscalculated as S_z = 81.956. The correct coefficient of variation is determined to be 6.13%. The calculations highlight the importance of verifying the normality of the data before applying these statistical methods.
  • Understanding of uniaxial strain and its mathematical representation.
  • Familiarity with normal distribution notation, specifically N(mean, variance).
  • Knowledge of statistical concepts such as mean, standard deviation, and coefficient of variation.
  • Ability to perform calculations involving ratios and relative errors.
  • Review the properties of normal distributions and their applications in engineering.
  • Learn about the derivation of the coefficient of variation and its significance in data analysis.
  • Investigate methods for testing the normality of data distributions.
  • Explore advanced statistical techniques for handling non-normally distributed data.
Engineers, statisticians, and students in fields requiring analysis of strain measurements and statistical data interpretation.
faust9
Here's the question:
In the expression for uniaxial strain e = d/l, the elongation is specified as
d ~ N(0.0015, 0.000092) in. and the length l ~ N(2.0000, 0.0081) in.
What are the mean, standard deviation, and coefficient of variation of the corresponding strain e?
so, I said the mean (X) of delta is 0.0015 and the standard deviation (S) of delta is 0.000092
[tex]X_d=0.0015, S_d=0.000092[/tex]
[tex]X_l=2.000, S_l=0.0081[/tex]
I said [tex]Z=d/l\ thus\ X_z=X_d/X_l[/tex] and the [tex]S_z^2=(C_d^2+C_l^2)/X_z^2[/tex]
So, I did the following: [tex]X_e=X_d/X_l=0.0015/2.000=0.00075[/tex]
and [tex]S_z=\sqrt{((0.000092/0.0015)^2+(0.0081/2.000)^2)/0.00075^2}=81.956[/tex]
The last part doesn't seem right though. Any thoughts?
Thanks.
If you denoted the relative errors by C
[tex]S_z^2=(C_d^2+C_l^2)*X_z^2[/tex] instead of what you used.
Your calculation for the mean and standard deviation of the strain e looks correct. However, the coefficient of variation (CV) is usually calculated as the ratio of the standard deviation to the mean, so in this case it would be 0.000092/0.0015 = 0.0613 or 6.13%. The value you calculated for the standard deviation of e (81.956) is quite large compared to the mean (0.00075), which indicates that the data may not be normally distributed. It might be worth checking the data and making sure it follows a normal distribution before using these calculations.
