How Is the Coefficient of Kinetic Friction Calculated in a Spring-Block System?
The coefficient of kinetic friction (µk) in a spring-block system can be calculated using the equation derived from the balance of forces at the point where the block stops. Given a spring constant (k) of 50 N/m, a block mass (M) of 5 kg, and an initial stretch distance (di) of 56 cm, the correct formula is µk = (k * x) / (m * g), where x is the final stretch of the spring and g is the acceleration due to gravity (9.81 m/s²). The calculated value of µk is 0.0603, but discrepancies may arise from rounding errors or unit inconsistencies. Ensuring precise calculations and consistent units is essential for accuracy.
  • Understanding of Hooke's Law and spring constants
  • Knowledge of basic physics concepts such as forces and friction
  • Familiarity with unit conversions (N/m to kg·m/s²)
  • Ability to perform calculations involving potential energy and work
  • Review the principles of Hooke's Law and its applications in mechanics
  • Learn about energy conservation in mechanical systems
  • Study the effects of friction on motion and how to calculate it
  • Practice solving problems involving spring forces and kinetic friction
Students and professionals in physics, mechanical engineering, and anyone interested in understanding the dynamics of spring-block systems and frictional forces.
Naeem
Q. A relaxed spring with spring constant k = 50 N/m is stretched a distance di = 56 cm and held there. A block of mass M = 5 kg is attached to the spring. The spring is then released from rest and contracts, dragging the block across a rough horizontal floor until it stops without passing through the relaxed position, at which point the spring is stretched by an amount df = di/9.
What is the coefficient of kinetic friction µk between the block and the floor?
Here is what I did:
At the point the block stops the spring force is equal to the force of friction.
Fspring = Ffriction
k*x = Uk * m * g
Uk = (K * x )/ m* g
Uk = 0.0603, which the computer says is wrong.
Note that they want the coefficient of kinetic friction.
Here is what I did:
Yes, when it stops the static friction will equal the spring force. But that's not what they want.
Instead, realize that some spring potential energy is transformed into work against friction.
Your approach to solving this problem is correct. However, there may be a small error in your calculation or rounding. I recommend double-checking your calculations and making sure to use the correct values for k, m, and g. Also, make sure to use the same units for all quantities (e.g. if k is in N/m, make sure m is in kg and g is in m/s^2). It is also possible that the computer's answer is slightly different due to rounding or significant figures. Overall, your approach is correct and you should be able to arrive at the correct answer with some careful calculations and attention to units.
  • · Replies 33 ·
  • · Replies 27 ·
11K
  • · Replies 58 ·
  • · Replies 16 ·
