Solving Proportion Problems: A Brain-Racking Challenge
  • Thread starter Thread starter simplywrite
The discussion revolves around proportion problems involving earnings, dimensions of pictures, and relationships between triangles. Participants are exploring how to set up and solve these proportion-related questions.
  • Mixed
  • Participants attempt to calculate earnings based on a weekly rate and question if additional steps are needed. They also explore how to maintain aspect ratios when resizing images and express dimensions in fractions. There are attempts to clarify the relationships between the dimensions of triangles and identify missing values.
Some participants provide feedback on the approaches taken, suggesting corrections to ratio setups and clarifying the relationships in the triangle problems. There is ongoing exploration of the correct methods to express and solve the problems, with no clear consensus reached yet.
Participants are working under the constraints of homework guidelines, which may limit the information they can use or the methods they can apply. There are indications of confusion regarding the correct setup of ratios and the interpretation of the problems.
simplywrite
This has been racking my brain for awhile, and I know I have it right, but something is missing.
1. A person earns 850 euros in one week. How much will she earn in 3.5 weeks?
This seemed simple enough, so I just multiplied 850 by 3.5 and got $2,975. I know there's one more step, and I can't find it.
2. A picture is 73/4 inches wide and 81/2 inches high. If you wish to enlarge the width to 10 inches, how high will the picture be? Express in fractions instead of decimals.
I converted the fractions into decimals so I can get the fraction answer. I came up with 7.75/8.5 = x/10 = I then got 77.5 over 8.5 and came up with 911/100. Obviously this is wrong, but I can't figure out the step I missed here.
3. There's 5/4 of a triangle and 2/x of another one, I'm supposed to find the missing piece.I come up with 8/5. I'm stuck on where to go from here.
Any help would be appericated.
This one's just fine---no missing steps.
You messed up the statement of ratios. It looks like you tried to use:
[tex]\frac{W_1}{H_1} = \frac{W_2}{H_2}[/tex]
But you put [itex]H_2 = 10[/itex] instead of [itex]W_2 = 10[/itex].
I don't understand this problem.
Right. You forgot to account for taxes ;). Just kidding, that looks correct to me.
I'd suggest staying with fractions if you're comforatable:
So you've got an inital aspect ratio:
[tex]\frac{width}{height}=\frac{\frac{73}{4}}{\frac{81}{2}}=\frac{146}{324}=\frac{73}{162}[/tex]
and then you want so solve for the same aspect ratio with a different width:
[tex]\frac{10}{h}=\frac{73}{162}[/tex]
[tex]10\times162=73 h[/tex]
[tex]\frac{1620}{73}=h[/tex]
Of course, since [tex]\frac{73}{4} > 10[/tex] and the problem mentions increase to 10 inches, I'm guessing you copied it incorrectly.
I can't quite follow what you're doing, but I'd guess that you'should be getting [tex]\frac{8}{5x}[/tex] instead of [tex]\frac{8}{5}[/tex].
The exact problem is
I have two triangles, one is 5 inches on the left and 4 inches at the bottom. Another one is 2 inches on the left side and x on the bottom. The idea is to find the missing piece of that one, that's what I was trying to say.
Can you fill in the spaces below?
5 is to 4 as _ is to _
5 is to 4 as 2 is to x.
One triange is 5 inches on the left, and 4 at the bottom. Another is 2 inches to the left. The idea is to find the x at the bottom of the other triange.
Let me redo this one:
A picture is 7 3/4 inches wide and is 8 1/2 inches high. If you enlarge the picture by 10 inches, how high will the picture be expressed as a fraction over a decimal?
  • · Replies 22 ·
