Help with an equilibrium problem
  • Thread starter Thread starter graphic7
    Equilibrium
The discussion focuses on solving an equilibrium problem involving the center of mass (COM) of a rod positioned in a bowl with a radius of 1. The user aims to derive equations for the y-coordinate of the COM, apply the potential energy equation, and utilize Newton's second law to find the angle theta where the rod meets the horizontal. The coordinates for the lower end of the rod are defined as x = -a cos(2θ) and y = -a sin(2θ), with the center of mass located at x = -a cos(2θ) + c cos(θ) and y = -a sin(2θ) + c sin(θ).
  • Understanding of center of mass calculations
  • Familiarity with Newton's second law
  • Knowledge of trigonometric functions and their applications
  • Basic principles of potential energy in physics
  • Study the derivation of center of mass equations in physics
  • Learn about potential energy and its role in equilibrium problems
  • Explore applications of Newton's second law in static systems
  • Investigate trigonometric identities and their use in solving geometric problems
Students studying physics, particularly those focusing on mechanics and equilibrium problems, as well as educators seeking to enhance their understanding of center of mass concepts.
graphic7
There's a problem I've been working on for the last few days on:
(problem number 4)
http://www.maths.usyd.edu.au:8000/u/leonp/MATH2004-2904/LDtute11.pdf
I'm trying to find the center of mass on that rod, and I'm having quite a bit of trouble. I'm only worried about a special case, when the radius of the bowl equals 1. If I can find equations for the COM for the y coordinate, I can apply the potential energy equation, and differeniate - giving Newton's second law. Then I'll be able to set the forces equal to zero, and solve for that angle theta at which the rod meets with the horizontal.
I take it you mean the center of mass in some sort of coordinate system- but you don't specify the coordinates.
I'm going to take the (0,0) at O, x-axis along the horizontal diameter of the bowl, y-axis vertical. Since the bowl has radius a and the lower end of the rod is at angle 2θ below the horizontal (the external angle is equal to the sum of the two opposite angles), the coordinates of that lower end are x= -a cos(2θ) and
y= -a sin(2θ). The length of the rod is 2c and it is uniform so the center of mass is geometric middle: distance c from the lower end. Looking at the right triangle formed by the rod (as hypotenuse), the vertical dropped from the center of mass and the horizontal from the lower end, we have Δx/c= cos(θ) and Δy/c= sin(θ). The center of mass of the rod is at
x= -acos(2θ)+ c cos(θ), y= -asin(2θ)+ c sin(θ)
Much appreciated.
  • · Replies 17 ·
