Why does heat reflect sunlight? (ie: mirages)
  • Context: High School
  • Thread starter Thread starter baywax
    Heat Sunlight
The discussion centers around the phenomenon of mirages and the underlying reasons for their occurrence, specifically exploring the role of heat and air density in the bending of light. Participants examine the concepts of reflection and refraction in relation to how heat affects sunlight perception.
  • One participant inquires about the relationship between heat and sunlight reflection in the context of mirages.
  • Another participant explains that heat causes air to rise, creating a gradient in air density, which in turn affects the refractive index of the air and bends light.
  • A further contribution describes how the density of air near hot surfaces decreases, leading to layers of varying density that influence light direction and can result in mirages.
  • One participant acknowledges the clarification that it is the air, not heat itself, that is responsible for the bending of light.
  • Another participant emphasizes that heat does not reflect sunlight but refracts it, reiterating the role of air in bending light paths.
Participants generally agree on the role of air density and refractive index in the phenomenon of mirages, but there is some confusion regarding the terminology of reflection versus refraction. Multiple viewpoints on the explanation exist, but no consensus is reached on the terminology used.
There is a lack of clarity regarding the definitions of reflection and refraction as they pertain to this discussion, and some assumptions about the nature of light behavior in different media are not fully explored.
baywax
The title of this thread is all I have to ask about this. You've seen mirages, if they are caused by light reflecting off heat I am wondering why this takes place. Thank you.
Science news on Phys.org
Heat causes air to rise which causes a gradient (a progression) in the density of air with height. This causes a gradient in the refractive index of the air, and that (the change in refractive index) bends the light.
Usually in hot desert, because of the hotness of the sand the density of the air which is close to it decreases and as we go higher/upper the density of air relatively increases so we can imagine them as layers.(as the pic has shown)
mirage.jpe
As we know that light changes its direction and speed when it travels from one dense medium to another dense medium, when this bend exceed the critical angel, it starts following the laws of reflection . . . and the reflection bends again and reaches to our eye . . . and thn we call it MIRAGE
Ah, thank you! I realized after posting that it was the air rather than the heat doing the reflecting. Thanks again!
I hate to be a stickler, but heat doesn't reflect sunlight; it refracts it. The air bends the light ray's path. Both sadaf2605 and cepheid are completely correct with their explanations. I just thought I point out that triviality.
My mistake, refracts. Thank you.
  • · Replies 66 ·
  • · Replies 24 ·
