Finding the Degree of a Map on S^3 and its Homotopy with the Identity
  • Context: Graduate
  • Thread starter Thread starter WWGD
    Degree Map
The discussion focuses on determining the degree of the map f: S^3 --> S^3 defined by (x1,x2,x3,x4) --> (-x2,-x3,-x4,-x1) and assessing its homotopy with the identity map. The computation reveals that f^4 is the identity, leading to the conclusion that the degree of f is either +1 or -1. The participants suggest calculating the determinant of the corresponding linear map in R^4 to ascertain whether f preserves or reverses orientation, ultimately confirming that f is homotopic to the identity and thus has a degree of 1.
  • Understanding of homotopy theory and degree of maps
  • Familiarity with the topology of S^3 and R^4
  • Knowledge of linear algebra, specifically determinants
  • Experience with homology and orientation preservation in topological spaces
  • Study the properties of homotopy equivalence in topological spaces
  • Learn about the computation of the degree of maps in algebraic topology
  • Explore the relationship between determinants and orientation in linear transformations
  • Investigate induced maps on homology groups for various topological spaces
Mathematicians, topologists, and students studying algebraic topology, particularly those interested in the properties of maps on spheres and their homotopic relationships.
WWGD
Hi: More on Prelims:
We have a map f: S^3 -->S^3 ; S^3 is the 3-sphere , given by:
(x1,x2,x3,x4)-->(-x2,-x3,-x4,-x1).
We're asked to find its degree, and to determine if f is homotopic to the identity.
I computed that f^4 ( i.e., fofofof ) is the identity, and we have that degree is
multiplicative, so that deg(f)^4=1 , so that we can narrow the choices to degf=+/- 1.
Now, I know we can also compute the induced map on top homology, and see if f is
preserving- or reversing- orientation, but I cannot tell which it is; I am trying to
use a 4-simplex , and see if this map preserves or reverses the orientation, but
I cannot see it clearly.
Another choice I am thinking of using is that f , seen as a map from R^4 to itself,
is a linear map, so that we can calculate Det f , to see if f reverses or preserves
orientation, and then maybe argue that f restricted to the subspace S^3 (unfortunately,
S^3 is not a subspace of R^4 ) has the same effect of preserving/reversing
orientation. Any Ideas/Suggestions/Comments?
see well how to do that
You're on the right track: you calculate the determinant of the matrix in R^4, then you check whether it flips the sign on the radial vector field.
I think you can also use this fact:
Given two maps f,g: S^n --->S^n
such that f(x)=/-g(x), then f,g are homotopic thru:
H(x,t)=[(1-t)f(x)+tg(x)]/|| (1-t)f(x)+tg(x) ||
So, your f, and Id are then homotopic and so degf=1
10K
