HELP:moment of inertia/angular momentum
  • Thread starter Thread starter buffgilville
    Momentum
The discussion focuses on calculating the angular momentum of a solid ball with a radius of 0.4 meters and a density of 1.7 kg/m³, rolling at a speed of 11.1 m/s. The initial calculation yielded an angular momentum of 0.809 Joule-seconds, but the correct answer is 2.83 Joule-seconds. This discrepancy arises from the need to change the axis of rotation to the contact point of the ball with the plane, requiring the use of the formula I = (2/5)MR² + MR² for accurate results.
  • Understanding of angular momentum and its dependence on the axis of rotation
  • Knowledge of the moment of inertia for solid spheres
  • Familiarity with basic physics concepts such as mass, density, and volume calculations
  • Ability to apply rotational dynamics equations
  • Study the calculation of moment of inertia for different shapes, focusing on solid spheres
  • Learn about the principles of angular momentum and its conservation
  • Explore the effects of changing the axis of rotation on angular momentum calculations
  • Investigate practical applications of angular momentum in real-world scenarios, such as rolling objects
Physics students, educators, and anyone interested in understanding rotational dynamics and angular momentum calculations.
buffgilville
A solid ball of radius 0.4 meters, made from a material of density 1.7 kG/cubic meter, rolls along a rough horizontal plane with a speed of 11.1 meters/sec. What is its angular momentum (in Joule.secs)?
density = mass/volume and volume of a sphere = (4/3)(pi)(r)^3
so the mass is 0.4557kg
I=(2/5)MR^2 ---> (2/5)*0.4557*(0.4)^2 = 0.02917
w=v/r ---> 11.1/0.4 = 27.75
L=Iw ---> 0.02917*27.75 = 0.809
Student response 0.809
Correct answer 2.83
You have to change the axis of rotation to the contact point of the ball with the plane. It's 2/5mr^2 + mr^2. This will give you the correct answer.
"A solid ball of radius 0.4 meters, made from a material of density 1.7 kG/cubic meter, rolls along a rough horizontal plane with a speed of 11.1 meters/sec. What is its angular momentum (in Joule.secs)?"
Cartoonkid has given you the approah they're probably after.
However, as it stands, this question is completely meaningless.
Angular momentum is computed RESPECTIVE to a point. If you haven't been given that, then the exercise is flawed.
18K
  • · Replies 17 ·
