New Reply
Triple product vector problem
Share Thread Thread Tools
Aug24-11, 05:07 PM   #1
Find [itex](\vec{a}\times \vec{b})\cdot \vec{c}[/itex] if [itex]\vec{a}=3\vec{m}+5\vec{n}[/itex], [itex]\vec{b}=\vec{m}-2\vec{n}[/itex], [itex]\vec{c}=2\vec{m}+7\vec{n}[/itex], [itex]|\vec{m}|=\frac{1}{2}[/itex], [itex]|\vec{n}|=3[/itex], [itex]\angle(\vec{m},\vec{n})=\frac{3\pi}{4}[/itex]
This is my approach:
[itex](\vec{a}\times\vec{b})\cdot\vec{c}=[(3\vec{m}+5\vec{n})\times(\vec{m}-2\vec{n})]\cdot(2\vec{m}+7\vec{n})=[3\vec{m}\times\vec{m}-6\vec{m}\times\vec{n}+5\vec{n}\times\vec{m}-10\vec{n}\times\vec{n}]\cdot(2\vec{m}+7\vec{n})=\bf(-11\vec{m}\times\vec{n})\cdot(2\vec{m}+7\vec{n})[/itex]
I stuck here. I don't know the coordinates of [itex]\vec{m}[/itex] and [itex]\vec{n}[/itex].
Maybe the whole approach is wrong. I don't have any other idea on solving this problem so I need your help.
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Ants and carnivorous plants conspire for mutualistic feeding
>> Forecast for Titan: Wild weather could be ahead
>> Researchers stitch defects into the world's thinnest semiconductor
Aug24-11, 05:58 PM   #2
Recognitions:
Homework Helper Homework Help
What are mxm and nxn? Go back and _look at the definition_ of a vector product.
RGV
Aug24-11, 06:12 PM   #3
mxm and nxn by the definition gives us 0. That doesn't change anything.
Aug24-11, 07:33 PM   #4
Recognitions:
Quote by chmate View Post
OK, I see now that you got rid of those terms; the results were hidden behind a popup that appeared on my screen before (but not now). Anyway, you now want to evaluate 11 mxn . (2m + 7n). Now go back and look at the definition of mxn; in particular, pay attention to the directions in which various vectors are pointing.
RGV
Aug25-11, 09:19 AM   #5
Hello Ray,
I did these operations: [itex](-11\vec{m}\times\vec{n})\cdot(2\vec{m}+7\vec{n})=(-11\vec{m}\times\vec{n})\cdot2\vec{m}+(-11\vec{m}\times\vec{n})\cdot7\vec{n}[/itex][itex]=[/itex]
[itex]=[/itex][itex]-22(\vec{m}\times\vec{n})\cdot\vec{m}-77(\vec{m}\times\vec{n})\cdot\vec{n}[/itex]
So, according to definition, the vector [itex]\vec{m}\times\vec{n}[/itex] is normal with the plane spanned by vectors [itex]\vec{m}[/itex] and [itex]\vec{n}[/itex], as a result I got 0 at the and. Is this correct? Are these operations I did allowed?
Aug25-11, 10:16 AM   #6
Recognitions:
Gold Membership Gold Member
hello chmate!
erm
before embarking on long calculations, always check the obvious
hint: what is b + c ?
… I got 0 at the and. Is this correct?
see above!
Aug25-11, 10:25 AM   #7
Hi tinytim,
I see now that the vectors are lineary dependent so 0 is the right answer.
I just want to have this question answered, are these operations I did legal?
Thank you
Aug25-11, 10:33 AM   #8
Recognitions:
let's see …
yes, that's fine
(and (A x B).B is always zero)
Aug25-11, 11:32 AM   #9
Recognitions:
Hi tinytim,
Thank you
Yes, everything is legal. You just used things like A*(B+C) = A*B + A*C and A*(rB) = r(A*B) for scalar r; these are true if * is either the dot product or the cross-product. You also used AxB = -BxA which is specific to the cross product. Of course, you could have written the answer right away, without any calculations, because you had (UxV).W, where U, V and W are all linear combinations of m and n, so all lie in the same plane containing m and n---hence UxV is perpendicular to W.
RGV
New Reply
Thread Tools
Similar Threads for: Triple product vector problem
Thread Forum Replies
Problem With Explanation of Inner Product of Vector and Dyad Differential Geometry 4
Cross Product and Triple Scalar Product Calculus & Beyond Homework 0
Vector Algebra - Vector Triple Product Proof Calculus & Beyond Homework 14
Vector Triple Product Calculus & Beyond Homework 3
confusing arken/weber problem (del in triple vector product) Introductory Physics Homework 8
