How long until the ball hits the ground?
  • Thread starter Thread starter hyde2042
    Ball Ground
The problem involves determining the time it takes for a ball thrown downward from a height of 30 meters with an initial velocity of 8 m/s to hit the ground, considering negligible air resistance and a gravitational acceleration of 9.8 m/s².
  • Exploratory, Problem interpretation, Assumption checking
  • Participants discuss the application of kinematic equations, with one attempting to use the equation for displacement while another questions the inclusion of time in the equation. There is confusion regarding the formulation of the problem and the resulting quadratic equation.
The discussion is ongoing, with participants exploring different interpretations of the equations involved. Some guidance has been offered regarding the nature of the equation, but there is no explicit consensus on how to proceed with the solution.
Participants are grappling with the setup of the kinematic equations and the transition to a quadratic form, indicating potential misunderstandings of the problem's structure.
hyde2042
A ball is thrown downward from a height of 30m at 8m/s. How long until it hits the ground?
(Air resistance is negligible and gravity is 9.8m/s
I tried deltaX=Vi+(1/2)a(t^2) and came out with 2.12, but the solution says it's 1.79.
30=8+(1/2)(9.8)(t^2)
22=4.9(t^2)
sqrt4.49=sqrt(t^2)
t=2.12
Are you not missing a t?
[tex]V = V_i + a t[/tex]
so
[tex]\Delta x = V_i \mathbb{t} + \frac12 a t^2[/tex]
Thank you, but I'm afraid I'm evenb more confused by the additional t.
I ended up at 30-8t=4.9(t^2)
What I keep doing after that seems to make it more complicated than it should be. COuld you possibly point me in the right direction? Thank you for your time.
It's a standard quadratic equation, of the form ax2 + bx + c = 0.
How do you solve one of those?
Ah... hate when I over look simple things. Thank you very much.
  • · Replies 38 ·
