What are the branch points for \log (z^2 + 2z + 3)?
  • Context: Graduate
  • Thread starter Thread starter Gh0stZA
    Branch Points
The discussion revolves around identifying the branch points of the logarithmic function \log(z^2 + 2z + 3). Participants explore the calculation of these branch points, the implications of the quadratic formula, and the analytic properties of the logarithm at specific points.
  • One participant requests assistance in calculating the branch points and finding a branch of \log(z^2 + 2z + 3) that is analytic at -1.
  • Another participant notes that the branch point of \log(z) is at z=0 and suggests solving the equation z^2 + 2z + 3 = 0 to find the branch points.
  • A participant claims to have found the branch points as -1 ± i, but later acknowledges a mistake after comparing with Wolfram Alpha, which provides -1 ± √2 i as the correct roots.
  • One participant asserts that Wolfram Alpha's result is correct, questioning the method used to arrive at the initial answer of -1 ± i.
  • After correcting their mistake, the participant asks about substituting the values back into the logarithmic expression, suggesting they found \log(2 - √2) and \log(2 + √2).
  • Another participant responds that no further action is needed to identify the branch points, emphasizing that substituting the zeros back into the quadratic should yield zero.
Participants express disagreement regarding the correct branch points, with one participant initially providing an incorrect answer and later aligning with another's correction. The discussion remains unresolved as to the implications of the identified branch points.
There are limitations in the discussion regarding the assumptions made in the calculations and the dependence on the quadratic formula. The resolution of the branch points is contingent on correctly applying these mathematical principles.
Gh0stZA
Hi everyone,
Could someone please help me calculate the branch points?
Find a branch of [tex]\log (z^2 + 2z + 3)[/tex] that is analytic at -1, and compute the derivative at -1.
The "branch point" of ln(z) itself is z= 0. So you need to solve [itex]z^2+ 2z+ 3= 0[/itex].
I did. My answer is [tex]-1 \pm i[/tex] but Wolfram Alpha gives it as [tex]-1 \pm \sqrt{2} i[/tex]
Well, since you don't say how you got [itex]-1\pm i[/itex], I can only say that Wolfram Alpha is correct.
I'm sorry, I made a stupid mistake with my quadratic formula. I now have the same answer as Wolfram.
So do I basically substitute the values back into the expression within the logarithm? In that case, I get [tex]\log(2-\sqrt{2})[/tex] and [tex]\log(2+\sqrt{2})[/tex]
No. You need do nothing more to identify the branch points and sides, if you back-substituted the zeros of that quadratic back into the quad, you should get zero.
  • · Replies 31 ·
  • · Replies 17 ·
