Open and Closed Relations: A Topological Approach to Evaluating Limits
  • Context: Graduate
  • Thread starter Thread starter alexfloo
    Closed Relations
The discussion revolves around the concepts of "open" and "closed" relations within the context of topology and metric spaces, particularly in relation to convergent sequences and their limits. Participants explore definitions, implications, and potential applications of these relations in evaluating limits, as well as the relationship between these concepts and topological properties.
  • One participant proposes defining "open" relations as those that do not necessarily hold in the limits of convergent sequences, while "closed" relations do imply this.
  • Another participant suggests that a relation R can be viewed as a subset of X x X, and that the closure of R corresponds to closed subsets in the induced product topology.
  • A question is raised about the equivalence of R being a closed subset of X x X and being a "closed relation," with a distinction made between metric spaces and general topological spaces.
  • It is noted that sequences may not suffice to characterize closure in general topological spaces, leading to the introduction of nets as a necessary concept.
  • One participant expresses a lack of familiarity with topological concepts, specifically nets, and indicates a desire to learn more.
  • Another participant mentions that the equivalence of closed relations and closed subsets requires the space to be first-countable, and discusses the implications for open relations and their topology.
Participants express varying degrees of agreement on the definitions and implications of open and closed relations, but there is no consensus on the broader applicability of these concepts outside of metric spaces. The discussion remains unresolved regarding the best definitions and their implications in different topological contexts.
Limitations include the dependence on the specific properties of metric spaces versus general topological spaces, and the unresolved nature of how open relations may or may not form a topology on the powerset of relations.
alexfloo
"Open" and "closed" relations
We know that if we have convergent sequences (xn) and (yn) in simply ordered metric space, then xn[itex]\leq[/itex]yn implies that the limits x and y have x[itex]\leq[/itex]y. Also, xn<yn.
My instinct on noting this is to say that "<" is an "open relation" on that metric space, and that "[itex]\leq[/itex]" is its "closure" in that this pair of relations shares a certain property of open sets and their closures in a topological sense.
More generally, I would define an "open" relation to be a relation such that, if it holds pairwise for two convergent sequences (or equivalently if it eventually holds pairwise), it does not necessarily hold in their limits. It is "closed" if this does imply that it holds in the limit. The "closure" of a relation R is the "strictest" (in some sense I'm not certain of) relation such that if R holds pairwise on two sequences, then the closure holds for the limits.
This seems like it would be a useful concept for evaluating limits, but a Google search didn't turn up anything with my particular terminology. Is this an actual developed topic? And if so, what it the common terminology for it?
A relation R can be seen as a subset of X x X, so what you are looking for is probably the closure of R as a subset of X x X in the induced product topology from X, where X is your ordered space. It is the smallest relation (as a set) which is closed (by your definition) and contains R. Closed relations correspond to closed subsets of X x X.
I would define open relations as relations corresponding to the open subsets of X x X, so that the space of open relations form a topology on the powerset of relations.
That was my intuition, but I wasn't sure about it. So it is the case that R being a closed subset of X x X is equivalent to R being a "closed relation" as above?
On metric spaces, yes.
In general topological spaces, no. The reason is that sequences are too weak to characterize the closure in topological spaces. So you need to work with nets. If you work with nets, then they become equivalent.
Thanks, I haven't really been exposed much to topologies in general, which is why I specified metric spaces in the original post. I'm not familiar with the idea of a net, but I definitely plan an looking it up. Thanks a lot, both of you!
Yes, I agree with micromass, I think we require the space to be first-countable in order for this to be equivalent. A closed relation (if seen as the smallest relation that contains the limit of its sequences), is not necessarily closed for a space that is not first-countable, but the closed subsets of X x X are certainly closed relations.
The open relations if defined as the complements of the closed relations is however not necessarily a topology on the powerset of relations.
But I think that my suggestion is the "best" way to define the closure if you want the open relations to be a topology (in that it is the finest topology that can be generated in such a way).
9K
  • · Replies 58 ·
