Are my answers right? (Calculus YAY )
  • Thread starter Thread starter FancyNut
The discussion revolves around convergence and divergence of series in calculus, specifically focusing on the behavior of various infinite series and power series. Participants are examining their answers to specific convergence questions and exploring the underlying mathematical principles.
  • Participants discuss the convergence of series involving logarithmic and trigonometric functions, questioning the limits of terms and the application of comparison tests. There is also exploration of the radius and domain of a power series using the ratio test.
Some participants have provided guidance on using comparison tests and the conditions for alternating series. There is an ongoing examination of assumptions regarding limits and the application of L'Hôpital's Rule, with differing opinions on its utility. The discussion reflects a mix of interpretations and attempts to clarify concepts without reaching a definitive consensus.
Participants express uncertainty about their calculations and the correctness of their answers, indicating a need for further clarification on specific mathematical principles and tests. There are mentions of potential issues with LaTeX formatting in the expressions shared.
FancyNut
Are my answers right? (Calculus! YAY!)
I need to know if my answers to these questions are correct... Any help is very much appreciated and thanks in advance. :)
Questions = bold
Does [tex]\sum \frac {ln k}{\sqrt k}[/tex] converge or diverge? limits are 0 to infinity.
answer: diverge because the limit of [tex]a_n[/tex] goes to 1 and not zero.
Does [tex]\sum \frac {cos^2 k}{k^2 +1}[/tex] converge or diverge? Limits are 0 to infinity.
answer: converge because it's smaller then [tex]\sum \frac {1}{k^2}[/tex] which converges because of the p-series test... I'm not sure about this since k is inside cosine... :(
What are the radius and domain of this power series: [tex]\sum \frac {n(x-3)^n}{2^(n+1)}[/tex] limits are 0 to infinity.
answer: Radius is 2 and domain is [ 1, 5)...
What I did here was the ratio test which ended up with a limit of [tex]\frac {1}{2}[/tex] and then got to x being between 1 and 5. I checked both points and the series diverges with 5 plugged in for x and converges (alternate series) when 1 is plugged in...
whew. Again, thanks for any help. This is pretty important right now.
How did you get that the limit of the terms is not zero? You might want to check this.
That's fine, you can compare the absolute values of the terms in your series to [tex]\frac{1}{k^{2}}[/tex] and conclude your series converges (absolutely). Remember the absolute value of the cos part is no greater than 1.
Something went wrong with your latex I think, is your series:
[tex]\sum \frac {n(x-3)^n}{2^{n+1}}[/tex]
When you put 1 in for x, what's your series? Can you state the conditions of the alternating series test?
Ugh, I knew I didn't get those right. :frown:
I just thought that both lnx and x^1/2 go to infinity slowly but they do end up getting bigger and bigger and in the end it's infinity over infinity which I guess is one... but I guessed wrong, right? :(
That's fine, you can compare the absolute values of the terms in your series to [tex]\frac{1}/{k^{2}}[/tex] and conclude your series converges (absolutely). Remember the absolute value of the cos part is no greater than 1.
nice to hear I do have a brain... not a good one though. :p
Yeah that's what I meant.
conditions for alternating series:
1) limit [tex]a_n[/tex] goes to zero
2) absolute value of [tex]a_n[/tex] is bigger then [tex]a_(n+1)[/tex] and the same for the values after that.
2) [tex]a_n > 0[/tex] and [tex]a_n+1 < 0[/tex] and it goes back to bigger then zero for n + 2 and then smaller for the one after that and so on...
When I plug in 1 I get:
[tex]\sum \frac {n(-2)^n}{2^n 2^}[/tex]
Now after that I don't really know what to do since the top 2 has a negative I'm not sure I can cancel it with the bottom... so I just assumed it's an alternating series. :redface:
x and x^1/2 both go to infinity, but x/(x^1/2) clearly doesn't go to 1.
I'm not sure you have the tools yet to deal with the limit of the terms of this series, but you don't need to in any case here (it won't actually help).
Try a simple comparison test, remembering that ln(x)>=1 if x is large enough.
You can cancel, and you can break up the numerator as [tex](-2)^n=(-1)^{n}2^{n}[/tex] then cancel. It's definitely an alternating series from the [tex](-1)^n[/tex] term, you are right about that (this is your condition 3)). But you can't conclude from the alternating series test that it converges unless you've verified 1) and 2) as well. Do the cancelling, then what do you say about these conditions?
For the first one, just because both terms go to infinity, this does not necessarily mean that the limit is one. Equations of the form [tex]\frac{0}{0}[/tex] or [tex]\frac{\infty}{\infty}[/tex] are known as the indeterminate case. They may both approach the same number, but one number may do it much faster than the other, for instance in the fraction [tex]\frac{x}{x^4}[/tex] both numbers approach [tex]\infty[/tex] as x approaches [tex]\infty[/tex], however x^4 does so much faster that the actual fraction overal approaches 0. A good way to find the limit of a function as it approaches infinity is to use l'hospital's Rule, basically take the dirivative of both the numerator and the denominator independently, and then evaluate those at the limit points. Using this rule you can find how the original function converges using the dirivatives of both parts of the fraction.
I'm sorry but I don't agree with you about L'Hopital's Theorem as the subsequent computation of derivatives can not only be tedious but misleading as in the case of
[tex]\lim_{x\rightarrow 0} \frac{\sin(\sqrt{x})}{\sqrt{x}}[/tex]
which CANNOT be computed using L'Hopital's Rule simply because the function is not differentiable at x = 0. However a mere substitution, viz. [tex]y=\sqrt{x}[/tex] gives the answer. Same goes for several rational functions which through a bit of thought can be reduced to previously known limits (some of which may have geometric significance).
Another example is
[tex]f(x) = \frac{\tan(x)}{\sec(x)}[/tex]
and we are required to find the limit of f(x) as x tends to 0. Clearly L'Hopital's Rule is a bad idea...a simpler way is to express the numerator and denominator (in the limit) in terms of sin(x) and cos(x) so the problem reduces to finding the limit of sin(x) as x tends to 0.
I'd suggest that you avoid overuse of the theorem and resort to it only when the function appears to be irreducible or when nothing else comes to mind. Often, a geometric or order of magnitude argument such as the one used by Lyuokdea is a good idea too.
Hope that helps...
Cheers
Vivek
[tex]\sum \frac {n(-1)^n}{ 2^}[/tex]
I'm guessing this goes to infinity and doesn't satisfy condition 1 for alternating series. :(
Thanks guys for all the help. I learned a lot from this. :)
  • · Replies 21 ·
  • · Replies 17 ·
