Finding Elements of Order 6 in Aut(Z720)
  • Context: Graduate
  • Thread starter Thread starter mehtamonica
    Groups
The discussion revolves around finding the number of elements of order 6 in the automorphism group Aut(Z720). Participants explore various approaches and reasoning related to group theory, specifically focusing on the structure of Aut(Z720) and its isomorphism to U(720), as well as the implications of the fundamental theorem of abelian groups.
  • One participant suggests that Aut(Z720) is isomorphic to U(720) and proposes a decomposition into cyclic groups, leading to the conclusion that Aut(Z720) ≅ Z2 × Z4 × Z4 × Z6.
  • Another participant raises a case where the order of one component is 3, questioning how many possibilities exist for that case and what the orders of the other components could be.
  • Further elaboration on the case with order 3 indicates that the least common multiple of the orders of the other components must equal 2, leading to multiple scenarios for their orders.
  • Concerns are raised about potential overcounting of elements, particularly when the same element configuration appears in different cases.
  • A later contribution presents an alternative method for counting elements of order 6, involving the structure of Z(720) and its generators, ultimately arriving at a count of 30 elements.
Participants express differing views on the counting methods and the implications of their calculations. There is no consensus on the final count of elements of order 6, as some participants challenge earlier counts and propose alternative reasoning.
Some calculations depend on the assumptions about the orders of elements in cyclic groups and the implications of the least common multiple in the context of direct products. The discussion reflects the complexity of counting elements in group theory without resolving all mathematical steps.
This discussion may be of interest to students and researchers in abstract algebra, particularly those studying group theory and automorphism groups.
mehtamonica
I have to find the number of elements in Aut(Z720) with order 6. Please suggest how to go about it.
1) Aut(Z720) isomorphic to U(720) (multiplicative group of units).
2 ) I am using the fundamental theorem of abelian group that a finite abelian group is isomorphic to the direct products of cyclic groups Zn.
In this case, 720=16×9×5.
Therefore, Aut(Z720)≅U(720)≅Z2×Z4×Z4×Z6.
Now, the possible orders of elements in Z2:1,2; Z4:1,2,4; Z6:1,2,3,6.
Using the result defining the order of an element in external direct products:
If 6=Order(a,b,c,d)=lcm(Order(a),Order(b),Order(c),Order(d)) then:
Case 1 : If Order(d)=6 then lcm(Order(a),Order(b),Order(c))=1 or 2.
Using the the result for cyclic groups:
for every divisor d of the order of a cyclic group G, there exists ϕ(d) elements in G with order d.
It seems there are 16 elements. I am not sure though.
Is this the correct way and how to proceed further? Please suggest.
Seems correct til now.
Now, another case that can pop up is when d has order 3. How many possibilities are there for d to have order 3? And what can a,b and c be then?
Case 2: If order of d = 3, then we need that lcm ( O(a), O(b), O(c))= 2
It can happen in three ways:
(a) O(a) = 2, O(b) = 1 or 2, O(c)= 1 or 2. (b) O(b) =2, O(a) = 1 or 2, O(c)= 1 or 2. (c) O(c)=2, O(a) = 1 or 2, O(b)= 1 or 2.
According to this, in each case, there can be 8 elements in all.
Total no. of elements 16 + 24 = 40.
Please suggest if it is correct .
No, firstly there are multiple elements of order 3 in [itex]\mathbb{Z}_6[/itex]. Furthermore, you have counted some elements multiple times.
For example a=b=c=2 occurs in cases (a), (b) and (c). So you have counted that three times.
(a) O(a) = 2, O(b) = 1 or 2, O(c)= 1 or 2. (b) O(b) =2, O(a) = 1 , O(c)= 1 or 2. (c) O(c)=2, O(a) = 1 , O(b)= 1.
According to this,
Total no. of elements 16 + 8 + 4 +2 = 30.
Please suggest if it is correct now.
According to this,
That seems to be correct now! :smile:
Thanks, you are a great teacher. :smile:
Here's how I'd solve that problem.
Z(720) is cyclic, meaning that it can be generated with one of its elements, a. That element has the property that ak = identity only if k is a multiple of 720.
It can also be generated by every ak, where k is relatively prime to 720.
So its automorphism group consists of all mappings a -> ak, where k is relatively prime to 720. There are 192 possible k's, meaning that Aut(Z(720)) has 192 elements.
To go further, look for prime factors of 720: 24 * 32 * 5. Thus,
Z(720) ~ Z(16) * Z(9) * Z(5)
Every element of Z(720) can be turned into a triplet of elements, one of each of the three groups on the right. A generator of Z(720) is thus
(generator of Z(16), generator of Z(9), generator of Z(5))
The same arguments about being relatively prime apply here also, and Aut(Z(16)) has order 8, Aut(Z(9)) has order 6, and Aut(Z(5)) has order 4.
Aut(Z(16)) ~ Z(4) * Z(2)
Aut(Z(9)) ~ Z(2) * Z(3)
Aut(Z(5)) ~ Z(4)
Aut(Z(720)) ~ Z(2)2 * Z(4)2 * Z(3)
We want to count how many elements of Aut(Z(720)) have order 6. That order is a product of 2 and 3, meaning that those elements can be found in this subgroup of Aut(Z(720)):
Z(2)4 * Z(3)
Doing careful counting yields (24 - 1) * (3 - 1) = 15 * 2 = 30
