Solving a Plank Problem: Find the Distance x?
  • Thread starter Thread starter nix
The problem involves a uniform plank supported at two points, with a portion overhanging one of the supports. The goal is to determine the maximum distance a person can walk on the overhanging part before the plank tips. The subject area includes concepts of equilibrium, forces, and torques in physics.
  • Participants discuss the setup of forces and torques, questioning the placement of the normal force and the distances used in torque calculations. There is a focus on understanding equilibrium conditions and the implications of the plank's tipping point.
Some participants have provided insights into the correct interpretation of the equilibrium conditions, suggesting that the normal force from one support may not be relevant when calculating torques. Others have noted that the distance x should be measured from the left support, leading to a more reasonable answer. The discussion is ongoing with various interpretations being explored.
Participants are navigating the constraints of the problem, including the requirement that the person must walk on the overhanging part of the plank and the implications of the plank's tipping point. There is an emphasis on understanding the physical setup and the forces involved without reaching a definitive conclusion.
nix
Hi
Im having some difficulty with this problem..i know I am getting the wrong answer but not sure why.
Question: A uniform plank of length 5.0m and weight 225N rests horizontally on two supports, with 1.1m of the plank hanging over the right support. To what distance x can a person who weighs 450N walk on the overhanging part of the plank before it just begins to tip?
Diagram:
p
i i
i - supports
p - person
----- - plank
the distance between the rightmost i and p is (x)
and the distance between the rightmost i and the edge of the plank is 1.1m
My (wrong) solution:
Sum of the forces in the y direction = 0
So..
0 = N(Normal from first support) + N(normal from second support) - Ww(Weight of the wood) - Wp(Weight of the person)
2N = Ww + Wp
N = (Ww +Wp)/2
Sum of the torques = 0
0 = Wp(x) - Ww(1.4) - N(3.9)
Wp(x) = Ww(1.4) + [(Ww +Wp)/2)](3.9)
subbing in the numerical values...
(450)x = (225)(1.4) + [(225 +450)/2](3.9)
x = 3.625
but this answer is wrong because x has to be less than 1.1 m! :frown:
thanks for your help :smile:
oh oh the diagram didnt work hmmm...
the plank is supported by two supports, one at the very left edge and the other 1.1 m from the right edge, the person is a distance x from the right support on the way to the right edge
Well, you're confused on a couple of points, even though you're getting the main idea. First of all, of course x won't be smaller than 1.1, since you're measuring x _from the left support_, not from the right support - the only condition is that it has to be between 4 and 5, therefore. Second, N should be two times bigger, because in equilibrium the weight of the plank and the man are not held up by two supports, it's held up only by the letmost one (think about it - would it matter in equilibrium if you just took the leftmost pillar away?). So you don't divide by two. Third, if you're calculating torques around the leftmost point, the lever arm for the weight of the plank is 2.5 m, not 1.4, and it should have the same sign as the torque contribution of the person (and the opposite of the contribution of the normal). Think about it - it's an important point.
These problems are much easier to solve if you set up the right equilibrium point. This time, the right pillar would've been a much cleaner choice (since, in equilibrium, the left pillar is supporting no weight so the contribution from its normal is zero - make sure you understand this point).
i did use the right pillar for the equilibirum choice...the N i was using in the torque equation refers to the torque for the left pillar and that's why its (5- 1.1) 3.9 m away.. i think i might be doing something wrong for calculating the torque for the weight of the wood ..is it supposed to be at the centre of the plank so the distance would be (2.5 - 1.1) 1.4m away?
yes. but, as i pointed out, there is no force being exerted on/by the left pillar during equilibrium, so the contribution from it is zero (in equilibrium, the man being at the farthest possible distance on the right, the plank is just about to lift from the left pillar, so it exerts no force on the pillar and, therefore, there is no normal force)
O i understand now...just because the question says just before the plank begins to tip, it doesn't necessarily mean that the plank is not raised above the support
I get 0.7m if i don't use normal force for the left pillar which is a lot more reasonable..and the question becomes much more simple
thanks so much duarh :)
that's what i got too. incidentally, it doesn't have to be raised above the support - in fact, it better not be, or you're starting to lose equilibrium. the condition is one of 'light touching'. :D like peaceful coexistence
12K
