Can Theta Be Determined from Antenna Field Pattern Equations?
  • Context: Graduate
  • Thread starter Thread starter yungman
The discussion focuses on determining the angle \(\theta\) from the antenna field pattern equation \(\frac{1}{N} \left[\frac{\sin(N\theta)}{\sin\theta}\right] = 0.7071\), where \(N\) is an integer greater than 1. The identity \(\sin N\theta = \sum_{k=0}^N \binom{N}{k} \cos^k \theta\,\sin^{N-k} \theta\,\sin\left(\frac{1}{2}(N-k)\pi\right)\) is suggested to derive a polynomial in \(\sin \theta\). For values of \(N\) greater than 3, numerical methods are necessary to solve for \(\theta\).
  • Understanding of antenna field pattern calculations
  • Familiarity with trigonometric identities
  • Knowledge of polynomial equations
  • Experience with numerical methods for solving equations
  • Research numerical methods for solving polynomial equations
  • Explore advanced trigonometric identities and their applications
  • Learn about antenna theory and field pattern analysis
  • Investigate software tools for numerical computation, such as MATLAB or Python's NumPy
Electrical engineers, antenna designers, and researchers involved in antenna theory and field pattern analysis will benefit from this discussion.
yungman
This is part of the antenna field pattern calculation, I want to find out is there any way to find the [itex]\;\theta\;[/itex] of this:
[tex]\frac 1 N \left[\frac {\sin(N\theta)}{sin\theta}\right]\;\hbox { = 0.7071 where N is an integer bigger than 1}[/tex]
you can use the identity
[itex]\sin N\theta = \sum_{k=0}^N \binom{N}{k} \cos^k \theta\,\sin^{N-k} \theta\,\sin\left(\frac{1}{2}(N-k)\pi\right)[/itex]
to obtain a polynomial in [itex]\sin \theta[/itex] which can then be solved for [itex]\theta[/itex]. However, you will probably need to solve it numerically for [itex]N>3[/itex].
