Integrate y''/y: Solving with Logs
  • Thread starter Thread starter *FaerieLight*
    Integrating
The discussion revolves around finding the integral of the expression y''/y with respect to x. Participants are exploring the implications of this integral within the context of differential equations and logarithmic relationships.
  • Some participants suggest integration by parts and substitutions involving u=1/y and dv=y''dy, while others express confusion about the relevance of these methods. There is a discussion about the nature of the integral and its solvability, with references to known results for simpler forms like y'/y.
The discussion is ongoing, with various approaches being proposed and questioned. Some participants express skepticism about the possibility of finding a closed-form solution, while others argue that the question remains meaningful despite the challenges. There is a recognition that the integral relates to well-studied differential equations.
Participants are grappling with the complexity of the integral and the assumptions about the function y and its derivatives. There is a shared understanding that the integral may not yield a straightforward solution, particularly due to the non-constant nature of the coefficients involved.
*FaerieLight*
How would you find the integral of y''/y (with respect to x)?
I have absolutely no idea how to begin. All I know is that if it were y'/y, it would be log(y) + c. Perhaps the integral here has something to do with logs.
Thanks a lot.
Try integration in parts, where f(x) = y''(x), g'(x) = 1/y(x).
You should arrive to a new integral you can solve...
Tomer's suggestion is good but I think a more common notation would be u= 1/y, dv= y'' dy.
Thanks a lot.
I don't see how either of these substitutions help to solve this problem. y is a function of x and the variable of integration is x.
I haven't for a second assumed x isn't the variable of integration.
However, trying to solve it now on paper I noticed that what I first though would be a solvable integral isn't really.
Do you have any ideas then?
If:
[tex]\frac{d}{dx}\left[\frac{y'}{y}+\left(\frac{d}{dx}\log y\right)^2\right]=\frac{y''}{y}[/tex]
then isn't:
[tex]\int \frac{y''}{y}=\frac{y'}{y}+\left(\frac{d}{dx}\log y\right)^2[/tex]
Not entirely sure guys. Just a start.
jackmell said:
If:
then isn't:
What you say is right, but I don't see how the first formula you wrote is correct.
Ok, it's wrong. Sorry.
It's ok, apparently we're all wrong :-)
No, it seems that the starting point in post #6 can't possibly be right. It could only be right if the derivative of the second term in brackets is zero, which can't possibly be true, in general.
I will be a bit more emphatic. You aren't going to find a nice closed form general solution with any such techniques.
Yeah, it is equivalent to asking what is a general formula for the solution of the following homogeneous, linear second order equation with non-constant coefficients:
y'' - f(x) y = 0
which is absurd (unless f(x) is special in some way).
y'' - f(x) y = 0
Why is this absurd? If I can say that [itex]\int\frac{y'(x)}{y(x)}[/itex] = ln(y(x)), which is a closed form general solution, why should the given integral be absurd?
I don't see any way to find a closed formula, but I also don't see why the question should be meaningless.
Tomer said:
Why is this absurd? If I can say that [itex]\int\frac{y'(x)}{y(x)}[/itex] = ln(y(x)), which is a closed form general solution (and is equivalent to finding f(x) in the equation y'(x) +f(x)y(x) = 0), why should the given integral be absurd?
It isn't meaningless, it is just well understood - it has been studied (stated as diff.eq.) for centuries. All facts about it are known. It is known that there are solutions for many common f(x), but no formula for a general solution.
I understand :p
