How far can the rocket go trough space?
  • Thread starter Thread starter sony
    Rocket Space
The discussion revolves around a physics problem involving a rocket launched from Earth that stops ascending at a height of 85 km with an initial vertical velocity of 3.8 km/s. Participants are exploring how far the rocket can travel after its engine stops, focusing on concepts of kinetic and potential energy.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants discuss the relationship between kinetic energy and potential energy, questioning the need for the rocket's mass in calculations. There are attempts to set up energy equations and clarify expressions for potential energy. Some participants express confusion about the criteria for the problem and how to equate energy expressions.
There is ongoing dialogue with participants providing guidance on energy conservation principles and the importance of unit consistency. Some participants have made progress in understanding the energy balance, while others continue to seek clarification on specific expressions and concepts.
Participants note the importance of converting units from kilometers to meters and emphasize the need to measure distances from the center of the Earth. There is also a mention of textbook references that may have caused confusion regarding kinetic energy expressions.
sony
Hi, I'm new to these boards. I hope I posted in the right category, (I believe collage is equivalent with gymnasium in Norway)
Here's the problem:
A rocket is fired of from the earth. The rocket's engine stops
85km above the Earth's surface, then the rocket has a vertical velocity
of 3,8km/s. How far can the rocket go? (how high)
I'm uncertain about the criterias here. The rocket keeps going til the
velocity is 0, right? Does the rocket only have potential energi at this point?
If I try and figure it out with this, I only get rubbish. In the answer the book hints that you should use Ep = -yMm/r. But you don't know the mass of the rocket... So I guess you should find another expression equaling Ep. Anyways, I'm stuck.
Thanks for the help!
You don't NEED the mass of the rocket, since the kinetic energy is also proportional to that mass.
Hence "m" is a common factor you can remove.
Thanks, but I still don't get it...
Sett opp energi-regnskapet.
Vær spesielt forsiktig med uttrykkene for potensiell energi.
Takk skal du ha, men jeg er fremdeles forvirret.
Hva er kriteriene her?
Ved 85km høyde har raketten E= Ek+Ep
Og ved maksimal høyde har raketten E=Ep?
Stemmer det så langt?
Og hvis jeg setter uttrykkene lik hverandre strykes jo omtrent alt?
Try determining the rocket's total energy at 85km. (KE + GPE)
That will be equal to the total energy it will have at the top of its flight when its velocity is zero. write out the formula for both situations (with the appropiate unknowns) equate them and solve. (as noted already, the mass of the rocket will drop out.)
Riktig; pass også på ENHETENE dine; lengdemålet du har fått oppgitt tall i er i km (eller km/s), gjør om disse til meter.
Altså, vi setter opp balanse av mekanisk energi (delt på massen m):
[tex]\frac{1}{2}v_{0}^{2}-\frac{\gamma{M}}{R_{0}}=-\frac{\gamma{M}}{R_{1}}[/tex]
Husk at avstandene skal måles fra jordsenteret..
Note:
Let's take this in English from now on..
No, since the two distances are unequal, the potential energy terms do NOT cancel.
Your unkown is [tex]R_{1}[/tex]
Ok, igjen, takk skal du ha!
In our textbook Ek = 1,5 * yMm / r
and Ep = -yMm / r
Sorry for being an imbecile, but I don't understand how to get your expression.
0,5 * yMm/r - yMm/r = - 0,5 yMm/r
How is V0 incorporated?
I forgot:
0,5 * yMm/r - yMm/r = - 0,5 yMm/x
and Ep = -yMm / r
What kind of textbook is this??
The kinetic energy is ALWAYS [tex]\frac{1}{2}mv^{2}[/tex] where m is the mass and v the velocity.
I believe you must have confused the expression for kinetic energy with its value of it in the solution of a particular problem in your book.
Sorry! I see it now, the general formula for E = 0.5mv^2 - yMm/r
Are you sure you are not confusing yourself with the expression for the ESCAPE VELOCITY?
I looked at the wrong expression, I think it's all clear now!
Thanks a lot for your help!
Ha en fin kveld.
Glad we agree on that! :smile:
Now, take particular care with your units in solving the problem!
Takk det samme!
Beklager at jeg maser nå, men dette forumet virket som et ganske flott sted. Postet jeg forresten i riktig kategori?
Uansett, det er kjekt å slippe å måtte vente til neste fysikktime for å få hjelp!
Sorry for nagging, shall write in english from now on.
Cheers! :D
If you hadn't posted it in the right place, the mentors would have been alerted and moved it to its proper place.
Since you did post it where it should be, that didn't happen..
Velkommen til PF!
