Explain why the electric field strength is zero
The discussion revolves around a physics problem involving electric charges, specifically focusing on the scenario of two charged metal spheres and the resulting electric field strength at a midpoint between them. The original poster expresses difficulty in understanding the reasoning behind the electric field strength being zero at that midpoint.
  • Participants discuss the application of Coulomb's law and the relationship between force, charge, and electric field strength. Some question the calculations and reasoning behind the electric field being zero at the midpoint, while others attempt to clarify the implications of charge distribution and distance.
The discussion is ongoing, with participants exploring different interpretations of the problem. Some have provided insights into relevant equations and concepts, but there is no explicit consensus on the reasoning behind the electric field strength being zero.
There is mention of specific values and constants, such as the force measurement and the distance between the charges, but the original poster indicates confusion regarding the calculations and the underlying principles. The problem context includes assumptions about charge distribution and the setup of the experiment.
MightyMeanie
I am stuck on my physics homework. I can manage the latter question, how ever when i work out the first one my working out has no rhyme nor reason (nor a right answer). Any help will be great.
A small metal sphere on an insulating rod is placed on a top pan balance, as shown in the diagram below. An identical metal sphere carrying a charge of 2Q on an insulating rod is brought into contact with th sphere on the balance so each sphere acquires the same charge.
When the two spheres are a separation of 68 mm, the top of the pan balance reading increases by 2.1 x 10 ^-3 N. Calculate the charge, Q, on each sphere.
Explain why the electric field strength is zero at the midpoint between the two charge.​
sorry just read the sticky after posting
This is how i attempted to do it, but then realized how completely stupid and random it was
F/Q = E = V/d -> v/o = (2.1 x 10 ^ -3) / 2 -> 1.05 x 10 ^-3
(1.05 x 10 ^ -3) / 0.068 = (2.1 x 10 ^ -3) / Q
Q= (2.1 x 10 ^-3) / (1.544 x 10 ^ -3)
= 0.136 C which is stupid
Coulomb's law states:
F = (k*q1*q2)/r^2
q1 = Q
q2 = 2Q
r = 68mm
k= Boltzmann constant (See your book for this value)
F = 2.1mN
Solve for Q
Once you have Q it should be easy to figure out the electric field due to each charge.
thank you!
  • · Replies 17 ·
  • · Replies 35 ·
9K
  • · Replies 18 ·
