| New Reply |
Carnot Cycle |
Share Thread |
| Aug29-11, 11:02 PM | #1 |
Carnot Cycle
Hi
From http://en.wikipedia.org/wiki/Carnot_cycle "Reversible isothermal expansion of the gas at the "hot" temperature, TH (isothermal heat addition). During this step the expanding gas makes the piston work on the surroundings. The gas expansion is propelled by absorption of quantity Q1 of heat from the high temperature reservoir." I was wondering why the work done on the surroundings at this stage does not count toward the total work output of the cycle and why it is not used? Thanks |
| Aug30-11, 08:48 PM | #2 |
It does.
In fact, from the first law of thermodynamics, you can make Heat = Work + Delta U, though as it is a cycle and U is a state variable, Delta U in the cycle is null, so the heat transferred is equal to work. |
| Aug30-11, 09:05 PM | #3 |
What about for a boiler? A boiler in a heat engine operating a Carnot cycle does not have a piston (it is rigid), in this case, although it is also responsible for Process 1-2 in a Carnot cycle it does no work right? Also, how does a rigid boiler maintain isothermal heat transfer? Thanks |
| Aug31-11, 01:06 PM | #4 |
Carnot Cycle
does the steam from the boiler go anywhere and do anything?
| New Reply |
Similar Threads for: Carnot Cycle
| carnot's cycle | Classical Physics | 1 | ||
| Carnot's cycle and a-like cycles | Classical Physics | 2 | ||
| The Carnot Cycle | Classical Physics | 4 | ||
| carnot cycle | Introductory Physics Homework | 1 | ||
| carnot cycle | Introductory Physics Homework | 3 | ||
