[Number Theory] Prove (x^2 - y^2) is not equal to 6.
The discussion revolves around proving that for any positive integers x and y, the expression (x^2 - y^2) is not equal to 6. This falls under the subject area of number theory, specifically dealing with properties of integers and algebraic expressions.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants explore a proof by contradiction, examining various cases for the factorization of 6. Some suggest a brute force method to check integer pairs, while others discuss the monotonicity of the function x^2 - (x-1)^2 as a potential approach. Questions arise regarding the understanding of monotonic functions and the implications of the derived expressions.
The discussion is active, with participants providing insights and alternative methods for approaching the problem. Some guidance has been offered regarding the proof of monotonicity, and there is an acknowledgment of the validity of the original proof attempt, although further clarification and exploration of concepts are ongoing.
Participants note the need to clarify certain mathematical concepts, such as monotonic functions, and the constraints of working with positive integers. There is also mention of the requirement to show that certain expressions are always greater than specific values under given conditions.
razefast
Prove the following proposition: For any positive integers x and y, (x^2 - y^2) is not equal to 6.
I'll try to prove using contradition.
Assume x^2 - y^2 = 6.
(x+y)(x-y) = 6
(x+y)=6 and (x-y)=1 (OR)
(x+y)=1 and (x-y)=6 (OR)
(x+y)=-6 and (x-y)=-1 (OR)
(x+y)=-1 and (x-y)=-6 (OR)
(x+y)=2 and (x-y)=3 (OR)
(x+y)=3 and (x-y)=2 (OR)
(x+y)=-2 and (x-y)=-3 (OR)
(x+y)=-3 and (x-y)=-2
When I solve those equations, x and y turns out to be fractions.
Therefore, there is a contradition.
Therefore, (x+y)(x-y) is not equal to 6.
Hi fellow physicsforumers
This is my first post. :D
I just started my discrete maths course at uni.
Is my solution correct?
Even if it is, is there any simpler way?
Thanks,
razefast
so its a proof of contradiction using cases - looks reasonable to me, though haven't done a heap of number theory
i think though you need to state somewhere that the only 2 integer factorisations of 6 are
1.6
2.3
-2.-3
-1.-6
interestingly, the brute force method is almost quicker here
clearly x>y>0 for this to be true
so say
x=2, y=1, x^2-y^2=3
x=3, y=2, x^2-y^2=5
x=3, y=1, x^2-y^2=8
x=4, y=3, x^2-y^2=7
however you would also need to show x^2-(x-1)^2 is an monotonically increasing function, but that shouldn't be too hard
Hi lanedance,
Actually, I have no idea how to prove x^2-(x-1)^2 is an monotonically increasing function :(
I have never learned about monotonic function so I had to google it but still confused. lol
Thanks for your reply lanedance :D
With regards,
razefast
x^2 - (x-1)^2 is easy to prove as monotonic, even without calculus. I will give a different example so you get the idea.
Monotonically Increasing Proof:
f(x) = x^2+3x+1
Prove that f(x) is monotonically increasing for x>0, that is,
If 0<a<b, then f(a)<f(b)
Let d=b-a => b=a+d.
f(b)=f(a+d)=(a+d)^2 + 3(a+d) +1 = a^2 + 2ad + d^2 + 3a + 3d + 1 = f(a) + (2a + d + 3)d
Now since 0<a<b, b-a>0 and so d>0. Thus (2a + d + 3)d > 0, and so f(b)>f(a).
The problem of proving x^2 - (x-1)^2 is monotonic should be similar. In fact, it is a little algebraically simpler, and you should not need a restriction of x>0.
adding onto process91's comments
monotonically increasing means it is always increasing as x gets bigger, or the derivative is always greater than zero
in terms of the proof, we just want to show the gap between x^2 and (x-1)^2 is always greater than 6 for x>4. That way we don't have to check any values of x>4
now expanding the difference
x^2-(x-1)^2 = x^2-(x^2-2x+1) = 2x-1
which is a straight line, hopefully you can convince yourself this is always increasing.
Now say you have two integers s and t, if t>s can you show 2t+1>2s+1? That would be enough.
All that said your original proof was fine with the extra line
. This is just another way of looking at it.
Hi lanedance and process91
Those explanations are quite clear.
I learned new things today.
Thx for helping out de newbie xD
Man..Physics forums is great ^^
Here's another way, let x = y + k and try to derive a contradiction.
