From Fourier Series to Fourier Transforms
The discussion revolves around the transition from Fourier Series to Fourier Transforms, specifically the logical steps involved in proving that the Fourier series of a function with an infinite period leads to the Fourier transform. Participants explore the mathematical foundations and reasoning behind this transition, including the treatment of Fourier coefficients and the conversion from summation to integration.
  • One participant seeks clarification on how the Fourier coefficients \(c_n\) transition to a continuous function \(c(k)\) as the period \(L\) approaches infinity, and why the summation becomes an integral.
  • Another participant expresses confusion about the transformation of the summation into an improper integral, referencing external sources that do not clarify this point.
  • A participant attempts to derive the transition by expressing the Fourier coefficients in terms of an integral and introducing a new variable \(k_n\), noting that as \(T\) approaches infinity, the spacing \(\Delta k_n\) approaches zero, suggesting a shift to continuous variables.
  • Further, a participant provides a more rigorous approach using properties of functions in \(C^\infty_c(\mathbb{R})\) and discusses the convergence of Riemann sums to integrals, referencing a mathematical text for support.
  • Another participant expresses gratitude for the rigorous explanation, indicating that it has clarified their understanding of the topic.
Participants generally agree on the need for a rigorous explanation of the transition from Fourier series to Fourier transforms, but there are multiple approaches and no consensus on a single definitive method or reasoning. Some participants express confusion, while others provide differing levels of rigor in their explanations.
The discussion includes various assumptions about the properties of functions and the conditions under which the Fourier series converges. There are unresolved steps in the transition from discrete to continuous representations, and the treatment of limits and integrals is not uniformly agreed upon.
mnb96
Hello,
I am trying to formalize the logical steps to prove that the Fourier Series of a function with period[itex]\rightarrow \infty[/itex] leads to the Fourier transform. So let's have the Fourier series:
[tex]f(x)=\sum_{n=-\infty}^{+\infty}c_n e^{i\cdot \frac{2\pi n}{L}x}[/tex]
where L is the period of the function f.
Many texts simply say that when L tends to infinity, cn becomes a continuous function [itex]c(n)[/itex] and the summation becomes an integral.
[tex]f(x) = \int_{-\infty}^{+\infty}c(k) e^{i\cdot k x}dk[/tex]
Unfortunately they do not explain why, and they do not mention what is the logical step that allows one to switch from the discrete cn to the continuous c(k), and from the summation to an integral with dk.
Any hint?
Uhm...so far, no replies.
I made the following attempt:
the Fourier coefficients cn are given by:
[tex]c_n = \frac{1}{T}\int_{-T/2}^{T/2}f(x)e^{-i\frac{2\pi}{T}nx}dx[/tex]
Plugging the cn's into the first equation in my first post one gets:
[tex]f(x) = \frac{1}{T} \sum_{n=-\infty}^{+\infty} \left( \int_{-T/2}^{T/2}f(x)e^{-i\frac{2\pi}{T}nx}dx \right) e^{i\frac{2\pi}{T}nx}[/tex]
Now we introduce the quantity [itex]k_n=n/T[/itex], and observe that [itex]\Delta k_n=k_{n+1}-k_n = 1/T[/itex].
Clearly, when [itex]T\rightarrow +\infty[/itex], we have [itex]\Delta k_n \rightarrow 0[/itex], and we replace the discrete quantity kn with a continuous variable u (this step is not rigorous!). As a consequence we must also replace the Fourier coefficients [itex]\{c_n\}[/itex] with a continuous variable c(u) (this step is not rigorous!)
In doing so we obtain:
[tex]f(x) = \Delta k_n \sum_{n=-\infty}^{+\infty} \left( \int_{-\infty}^{+\infty}f(x)e^{-i\ 2\pi u x}dx \right) e^{i 2\pi k_n x} = \Delta k_n \sum_{n=-\infty}^{+\infty} c(k_n) e^{i 2\pi k_n x}[/tex]
The rightmost term is a Riemann sum, so we write:
[tex]f(x) = \int_{-\infty}^{+\infty} c(u) e^{i 2\pi u x}du[/tex]
Which is the continuous inverse Fourier transform of c(u)
I hope someone else will put this into a more rigorous form and spot possible mistakes.
Your argument has the right idea. Let [itex]f\in C^\infty_c (\mathbf{R})[/itex] and choose [itex]\epsilon>0[/itex] sufficiently small so that [itex]\mathrm{supp}(f) \subset (-1/\epsilon, 1/\epsilon)[/itex]. Then [itex]f[/itex] has the convergent Fourier series [tex]f(x) = \sum_{n\in \mathbf{Z}} c_n e^{\mathrm{i} \pi \epsilon n x}[/tex]where
[tex]c_n = \frac{\epsilon}{2} \int e^{-\mathrm{i} \pi \epsilon n x} f(x)\, \mathrm{d}x.[/tex]
Set [itex]K_\epsilon = \{ k\in \mathbf{R} : k/\pi \epsilon \in \mathbf{Z} \}[/itex]. Then this can be written
[tex]f(x) = \sum_{k \in K_\epsilon} \frac{\hat{f}(k)e^{\mathrm{i} kx}}{2\pi } (\pi \epsilon) \qquad (*)[/tex]
where
[tex]\hat{f}(k) = \int e^{-\mathrm{i} kx} f(x)\, \mathrm{d}x.[/tex]
Note that [itex]\mathbf{R}[/itex] is the disjoint union of intervals of length [itex](\pi \epsilon)[/itex] centered about the points in [itex]K_\epsilon[/itex], it follows that [itex](*)[/itex] is the Riemann sum for the integral
[tex]\frac{1}{2\pi} \int e^{\mathrm{i} kx} \hat{f}(k)\, \mathrm{d} k.[/tex]
Since [itex]f\in C^\infty_c (\mathbf{R})[/itex] it follows that [itex]\hat{f}(k)e^{\mathrm{i} kx}[/itex] is integrable, so the Riemann sums converge to the integral as [itex]\epsilon\rightarrow 0[/itex], so you are done. The result extends to larger function spaces using standard density results.
Reed & Simon [Methods of Mathematical Physics, Vol II] use this approach to prove the Fourier inversion theorem. It allows you to prove many of the "usual" results for Fourier transforms using the corresponding results from Fourier series.
Hi Anthony!
Thanks a lot for providing a rigorous approach to this problem!
The explanation is now much clearer and easier to follow.
No problem - glad to be of service.
  • · Replies 33 ·
9K
  • · Replies 23 ·
