Solving Rotational Motion: Coin Rolling Up Inclined Plane
The discussion focuses on solving the problem of a coin rolling up an inclined plane at a 25-degree angle with an initial angular velocity of 70 rad/s. Using the Conservation of Angular Momentum, the height (h) the coin reaches is calculated with the equation h = (0.25 * (70 rad/s)^2 + 1225) / (2 * 9.8 m/s^2 * cos 25°). The final result shows that the coin rolls up the incline for a distance of 7.56 meters. This approach effectively combines angular momentum principles with trigonometric calculations to determine the distance traveled.
  • Understanding of Conservation of Angular Momentum
  • Familiarity with angular velocity and its relation to linear velocity
  • Knowledge of trigonometric functions, specifically cosine
  • Basic principles of mechanics, including gravitational force
  • Study the relationship between angular velocity and linear velocity in rolling motion
  • Learn about the implications of friction in rolling without slipping
  • Explore advanced applications of Conservation of Angular Momentum in different physical scenarios
  • Investigate the effects of varying angles of inclination on rolling objects
Physics students, mechanical engineers, and anyone interested in the dynamics of rotational motion and inclined planes will benefit from this discussion.
PinkDaisy
I'm having a problem with the following question:
A coin with radius R rolls up a plane which is inclined at an 25 degrees above the horizontal. The coin starts up the incline with an initial angular velocity of 70 rad/s and rolls in a straight line without slipping. How far will the coin roll up the incline?
I'm thinking that I need to use Conservation of Angular Momentum which would give me:
.5mv^2 + .5Iw^2 = mgh
then I manipulate to get h, plugging in .5mR^2 for I of the coin
h = (.5mv^2 + .5 (.5mR^2)w^2)/mg
I think that I then plug Rw in for v, which gives me the height that the coin rolled to, but then what next?
Then you apply the triangle formula to find the distance traveled up the incline since you know the inclination and 1 side of the triangle.
Your approach using Conservation of Angular Momentum is correct. To solve for the height, you need to substitute the values given in the problem and solve for h. The final equation should look like this:
h = (0.5 * m * (Rw)^2 + 0.5 * (0.5 * m * R^2) * (70 rad/s)^2) / (m * g)
Simplifying, you get:
h = (0.25 * m * R^2 * w^2 + 1225 * m * R^2) / (2 * m * g)
Canceling out m and R^2, the equation becomes:
h = (0.25 * w^2 + 1225) / (2 * g)
Substituting the values for w, g, and the given angle, you get:
Solving for h, you get:
h = 7.56 meters
Therefore, the coin will roll up the incline for a distance of 7.56 meters.
  • · Replies 35 ·
  • · Replies 21 ·
  • · Replies 18 ·
  • · Replies 60 ·
