Help please Find the truth value of the statement:
  • Thread starter Thread starter amandamarieve
    Value
The problem involves determining the truth value of a logical statement given specific truth values for variables P, Q, and R. The statement in question is structured using logical operators including negation, conjunction, and implication.
  • Conceptual clarification, Mathematical reasoning
  • Participants discuss two different approaches to evaluating the truth value, comparing results from two proposed answers. Questions are raised about the correctness of these answers and the interpretation of logical symbols.
Some participants have provided explanations of logical operators and their meanings, while others are exploring the implications of different interpretations of the original statement. There is no explicit consensus on the correctness of the answers presented.
Participants are working under the constraints of a homework assignment, which may limit the information available for discussion. There are also questions regarding the substitution of truth values into the original statement.
amandamarieve
Given P is true, Q is true, and R is fale, find the truth value of the statement:
~(~p ^ q) <-> (q -> ~r)
2. The attempt at a solution
Which one is correct- Answer 1 or answer 2?
answer 1:
p v ~q <-> (q -> ~r)
t V f <-> (t -> t)
t <-> t
Answer= t
answer 2:
p ^ ~q <-> (q -> ~r)
t ^ f <-> (t -> t)
f <-> t
Answer= f
Answer 1 is correct. Answer 2 isn't. Why not? And why didn't you just substitute P=t, Q=t and R=f into the original statement?
Could someone explain explain how I should read this: <->
and what does this mean: ->
Thanks.
<-> is "if and only if". P<-> Q is true if the true values of P and Q are the same: both T or both F.
Truth table:
[tex]\begin{array}{ccc} & T & F\\ T & T & F \\ F & F & T\end{array}[/tex]
where across is Q and down is P.
-> is "implication" P->Q "P implies Q" or "If P then Q" is true in the case that Q is true or both P and Q are false. Truth table:
[tex]\begin{array}{ccc} & T & F\\ T & T & F \\ F & T & T\end{array}[/tex]
As for amandamarieve's problem, ~(~p ^ q) <-> (q -> ~r), with p= q= T, r= f,
"~p ^q" is "F ^ T" which is F so ~(~p ^q) is T. That is, of course, the same as you get by using the fact that ~(~p ^ q)= ~(~p) v (~q)= p v ~q. On the right, q-> ~r, with q T and r F, is T->T which is T. We have T<->T which is T.
amandamarieve's "answer 2" is wrong because, as I said, ~(~p^q) is pv ~q, not "p^ ~q. In general, ~(p ^ q)= ~p v ~q and ~(p v q)= ~p ^ ~ q.
Thank you.
