Matlab: Problem with structures
  • Context: MATLAB
  • Thread starter Thread starter craigpmorgan
    Matlab Structures
The discussion addresses a coding issue in MATLAB where a structure assignment fails when the variable 'id' is 10 or greater. The error message indicates insufficient outputs for comma-separated list expansion, likely due to incorrect data type handling. A proposed solution is to convert 'id' to a numeric value using the str2double function, ensuring proper indexing of the structure. This adjustment resolves the issue by preventing MATLAB from misinterpreting the 'id' as a string array.
  • Familiarity with MATLAB programming language
  • Understanding of MATLAB structures and their usage
  • Knowledge of data type conversions in MATLAB
  • Basic debugging skills in MATLAB
  • Explore MATLAB structure data types and their properties
  • Learn about the str2double function for data type conversion
  • Investigate error handling and debugging techniques in MATLAB
  • Study object-oriented programming concepts in MATLAB, particularly classes
MATLAB programmers, data analysts, and anyone troubleshooting structure-related errors in MATLAB code.
craigpmorgan
Hi All,
I've written some code in Matlab that calculates a number of parameters and saves the data to a structure. A portion of the code is shown below:
uniqueName = genvarname(date);
plant(id).(uniqueName) = {date avgHeight avgVol};
The various parameters such as avgHeight etc. are defined earlier in the program. The confusing thing is that the code works fine when 'id' is a single digit number. However, when 'id' >= 10, the program returns the following error:
? Insufficient outputs from right hand side to satisfy comma separated
list expansion on left hand side. Missing [] are the most likely cause.
I don't understand the error message and don't know what to do next.
Any help I receive will be greatly appreciated.
Thanks very much for your time,
Craig
You might consider building a class instead of using a struct.
As for the error, there's not much to go on without having more code.
As far as I know, a structure is a type of class in MATLAB:http://www.mathworks.com/help/techdoc/matlab_oop/brh2rgw.html#brgljyu
craigpmorgan, try:
plant(str2double(id)).(uniqueName) = {date avgHeight avgVol};
so that you convert id to a number in case it's a string. It seems to me like it's interpreting 10 (for instance) as a 1 and 0 in a string array, rather than a single 10 in a number array.
10K
9K
