Understanding the Mass and Density of Empty Aluminum Cans
  • Thread starter Thread starter Bcisewski
    Density Mass
The mass of a pile of empty aluminum cans cannot be calculated using the formula m = ρV with ρ as the density of solid aluminum (2700 kg/m³) because the cans are not filled with aluminum. Instead, they contain air, which significantly reduces the average density of the pile. The volume of the cans (1.0 m³) does not equate to a mass of 2700 kg due to the presence of empty space within each can. Understanding this distinction is crucial for accurate mass calculations in similar scenarios.
  • Understanding of density and mass formulas (m = ρV)
  • Basic knowledge of the properties of aluminum
  • Familiarity with concepts of volume and empty space
  • Awareness of how air affects overall density in materials
  • Research the concept of average density in composite materials
  • Explore the physical properties of aluminum and its applications
  • Learn about the effects of air on the density of various materials
  • Investigate methods for calculating mass in irregularly shaped objects
Students in physics or engineering, material scientists, and anyone interested in understanding the principles of density and mass in everyday objects.
Bcisewski
Please correct me if wrong, but to explain why the mass of the pile is not pV = (2700 kg/m3)(1.0 m3) = 2700 kg, is because a pile of empty cans, its volume would be more of a dimension vs a weight. please explain concept if someone can. Thank you
Question: A pile of empty aluminum cans has a volume of 1.0 m3. The density of aluminum is 2700 kg/m3. Explain why the mass of the pile is not "p(alumin)*V "= (2700 kg/m3)(1.0 m3) = 2700 kg. Used from the formula p=m/V
The mass of some volume of stuff is [itex]m = \rho V[/itex], where [itex]\rho[/itex] is the density of whatever stuff fills the volume. Only if it were solid aluminum, would [itex]\rho[/itex] equal the density of aluminum. An empty can is mostly air, so the average density is much less than that of pure aluminum.
Thanks for the assistance, I overlooked the cans as having space within. I guess sometime the obvious to some may be difficult to see for others.
