What are the solutions for ln(z) = -1?
  • Context: Undergrad
  • Thread starter Thread starter Claire84
    Ln Negative
The discussion revolves around finding all solutions for the equation ln(z) = -1, exploring both real and complex solutions. Participants engage with the properties of logarithms in the complex plane, including the implications of the argument of z.
  • Some participants propose that the principal value of ln(z) leads to z = 1/e, while questioning if other solutions exist.
  • Others argue that the general solution should include terms like (1/e)e^(2kπ) for integer k, indicating the multi-valued nature of the logarithm in the complex plane.
  • A later reply emphasizes that the argument of z can take multiple values, leading to different representations of the solution.
  • Some participants express confusion about the relationship between real and imaginary parts of the logarithm and the implications for the argument of z.
  • One participant suggests that ln(z) being a multi-valued function means there could be multiple solutions, while another insists that applying the inverse function leads to a single solution.
  • There is a discussion about whether to express the solution in polar form or Cartesian form, with differing opinions on the necessity of showing all values of arg(z).
  • Clarifications are made regarding the identity e^(i2kπ) = 1 for any integer k, with some participants seeking further understanding of this concept.
Participants do not reach a consensus on whether there is only one solution or multiple solutions, as some maintain that only z = 1/e is valid, while others assert that the general form includes additional terms based on the argument.
Participants express uncertainty about the implications of the logarithm's multi-valued nature and the conditions under which different solutions may be valid. There are also discussions about the importance of distinguishing between principal values and general solutions.
Claire84
Hey there, I'm trying to work out all the solutions of z for ln(z)=-1. I let -1=ln|z| so then I took exponentials of both sides so I had e^(-1)=|z| so 1/e would equal z. I wasn't sure about having z also equal to -1/e, because since ln(z) = ln|z| + iarg(z) then for z=-1/e then the arg (z) would have to be pi or something... If anyone could help it would be great cos with the way the question has been asked about finding ALL the solutions, I think I'm missing something here. Thanks. :smile:
In my text,
log(z) = log r + i [itex]\Theta[/itex]
r = |z|
[itex]\Theta[/itex]= arg z
As suggested above, simply write [itex]z=re^{i\theta}[/itex] and compare real and imaginary parts.
Yeah, I did that but I just got 1/e... I'm getting kinda confused. Could you have something like (1/e)e^(2mpi) where m is 0, +1, -1 etc...?
No,you're left just with the "ugly" solution [tex]z=e^{-&1}[/tex].
Remember,even for imaginary arguments,the exponential and the natural logarithm are still one the inverse of the other.
That's all I had to do? So I definitely don't have to have different values for the argument like 0 (which was what I thought we had here) and then +2pi, -2pi etc? Cos I wasn't sure if by just putting down e^-1 I was just calculating the principal value...
Did you look at and understand mine and Gokuls posts?
for ln(-1)
r = |-1| = 1
[itex]\Theta= \pi[/itex]
So the PRINCIPLE Value of Ln(-1) = ln 1 + i [itex]\pi[/itex]
With a bit of thought you ought to be able to find the rest of the solutions.
Edit: If you have a real number answer there must be something wrong, since ln (-1) does not exist in the Reals. Isn't it obvious that your answer must be imaginary?
I'm confused (story of my life). I'm finding ln(z) = -1, so ln|z| +iarg(z) =-1, so I don't really get where the ln(-1) bit comes from... I just thought you'd compare real and imaginary parts or something here.
Thanks everyone for helping me btw, I really appreciate it. :smile:
But my z is real is it not, since it's 1/e or something...
Claire, I believe you have the right answer with z=1/e. Don't think there's any other solution.
I apologize for my previous post!
>>Yeah, I did that but I just got 1/e... I'm getting kinda confused. Could you have something like (1/e)e^(2mpi) where m is 0, +1, -1 etc...?<<
Yes.
Instead of using your previous formula (which gives only principal value) use the generalized one
ln(z) = ln|z| + i ([tex]\theta[/tex]+2*k*pi) where k is any integer.
Since the i component needs to be zero, solve for [tex]\theta[/tex].
S would we just have -1 = ln|z| + iarg(z) so the ln|z| part would give us the real part (say r), which would be 1/e. Then arg (z)= 2kpi where k is any integer. But would you then have to write this in polar form to indicate ALL the solutions cos writing it in cartesian form wouldn't give this, right? So would we have to write it like re^(itheta)? Would that then give us (1/e)e^(i2kpi) which would the give us e^(-1 + i2kpi)? Or would you not need to bother with that very last bit there? Or would it be better to write it in the form z = r(costheta + isintheta)?
It would be -1=ln|z|+i(arg(z)+2kpi)
arg(z)+2kpi=0 => arg(z)=-2kpi
since k is any integer we can rewrite, arg(z)=2kpi and get rid of the '-'.
so you'd have z=(1/e)e^(i2kpi) The thing is that e^(i2kpi)=1 for any integer k, so I'm not sure if you should give (1) z=1/e, or (2) z=(1/e)e^(i2kpi) as your final answer.
They are technically equivalent but the second shows that you considered all values of arg(z), whereas the first is more simplified.
Hope this helps.
Thanks for that. :smile:
Sorry if I'm being super-dozey here, but why is e^(i2kpi) = 1 for any integer k?
Btw, I get that it would be for k=0, but not for the other k values...
there will only be one solution, 1/e. ln(x) is a multivalued function in the complex plane, but its inverse e^x isn't. To solve this equation, you just apply the inverse to both sides, and since its single valued, you get a single answer. An analogy would be sin and arcsin. the equation arcsin(z)=0.5 has only one solution, z=sin(0.5), but the equation sin(z)=0.5 has an infinite number of solutions, z=arcsin(0.5)+2*pi*n for all integers n.
I think I like Status's answer, as it more appeals to my mathematical common sense.
e^(i2kpi)=cos(2kpi) + i sin (2kpi)=1+i0=1 (since cos 2kpi is always 1, and sin2kpi is always 0 for any integer k)
Claire, look at Status' post. I think he gives the easiest solution.
My apologies, I, for some reason was reading z = Ln(-1), which is a bit more interesting question of complex analysis.
No problem. Thanks everyone for all your help. I was even asking my lecurer about it today and he wasn't sure so you've been great. Thank you. :smile:
