Magnitude/direction of point charges
The net electrostatic force on point charge q3, with q = +1.5 µC and d = 27 cm, was calculated with Fx = 1.7 N and Fy = 3.3 N. The total force magnitude was incorrectly stated as 3.3 N; the correct total magnitude is calculated using the formula F = √(Fx² + Fy²), resulting in approximately 3.8 N. The angle of the force direction was miscalculated as 62.74 degrees using tan^-1(Fy/Fx), which requires verification of the correct magnitude before recalculating the angle.
  • Understanding of electrostatics and Coulomb's Law
  • Proficiency in vector addition and trigonometry
  • Familiarity with calculating forces in two dimensions
  • Knowledge of units in the metric system, specifically microcoulombs (µC) and newtons (N)
  • Review vector addition techniques in physics
  • Learn how to apply the Pythagorean theorem to calculate resultant forces
  • Study the concept of angles in trigonometry, particularly in relation to force vectors
  • Explore electrostatic force calculations involving multiple point charges
Students studying physics, particularly those focusing on electrostatics and force calculations, as well as educators looking for examples of common mistakes in vector analysis.
ajmCane22
(a) Find the magnitude and direction of the net electrostatic force exerted on the point charge q3 in the figure below. Let q = +1.5 µC and d = 27 cm.
http://www.webassign.net/walker/19-31.gif
I found Fx = 1.7 N and Fy = 3.3 N. So the total magnitude was 3.3 N. This part was correct, however when I tried to find the magnitude usting tan^-1(Fy/Fx) = tan^-1(3.3/1.7) = 62.74 degress the answer is wrong. It says I'm within 10%, but still wrong. I don't understand why. Please help
I found Fx = 1.7 N and Fy = 3.3 N. So the total magnitude was 3.3 N. This part was correct, however when I tried to find the magnitude using tan^-1(Fy/Fx) = tan^-1(3.3/1.7) = 62.74 degrees the answer is wrong. It says I'm within 10%, but still wrong. I don't understand why. Please help
If Fx = 1.7 N and Fy = 3.3 N , then the magnitude of F cannot be 3.3 N
Show your work so we can help find where you're going wrong.
  • · Replies 22 ·
11K
17K
13K
11K
