Is there a connection between them?
  • Context: Graduate
  • Thread starter Thread starter dragonlorder
    Forms Weird
The discussion revolves around the relationship between differential forms in Cartesian and polar coordinates, specifically examining the pullback of forms under coordinate transformations. Participants explore the implications of these transformations and the definitions involved in the context of smooth manifolds.
  • One participant expresses confusion about the relationship between the differential forms in Cartesian coordinates and their representation in polar coordinates, noting that the pullback seems to yield the same form.
  • Another participant explains that computing the form in polar coordinates involves the pullback of the Cartesian form by the inverse of the coordinate transformation, leading to a return to the original form.
  • It is suggested that the transformation F is not the identity function, as it represents a change in coordinates rather than a direct identity mapping.
  • A later reply clarifies that the form can be expressed in different coordinate systems, emphasizing that the manifold remains the same while the representation changes.
  • One participant questions the presence of the pullback operator in the context of Lee's writing, suggesting a potential misunderstanding of the coordinate chart changes versus changes in the manifold itself.
  • Another participant reiterates that the form can be expressed locally in different coordinate systems, affirming the idea of local representations of forms around points in the manifold.
  • Confusion arises regarding the identity nature of the transformation and its implications for the relationship between the coordinate systems.
Participants express varying levels of understanding regarding the nature of the transformations and the pullback operation. There is no consensus on the interpretation of the identity function in this context, and some confusion remains about the implications of the coordinate transformations.
Participants note that the transformation F must be defined on specific domains to be a diffeomorphism, and there are discussions about the implications of this definition on the identity nature of the transformation.
This discussion may be useful for those studying differential geometry, smooth manifolds, and the interplay between different coordinate systems in mathematical physics.
dragonlorder
I know this may sounds silly but I am confused
consider this two form for example, by substitution, I get
[tex]\omega = dx \wedge dy = d(rCos\theta)\wedge d(rSin\theta) = r dr \wedge d\theta[/tex]
also consider this smooth map [tex]F(x,y)=(rCos\theta,rSin\theta)[/tex]
then [tex]F^{*}\omega = rdr \wedge d\theta[/tex]
which means that [tex]F^{*}\omega= \omega[/tex]!?, that's just weird.
I am reading John's Lee smooth manifold book. and I saw the substitution writing at the differential form chapter. and the pullback writing at the Covector field chapter.
When you compute dxdy in polar coordinates, what you are doing is you're computing the pullback of dxdy by F-1. So of course when you then apply F* to the form in polar coordinates, you fall back on dxdy since you're computing
F* o (F-1)* dxdy = (F-1 o F)* dxdy = Id* dxdy = dxdy
Review the definitions if you need to.
In the case above, [tex]F:\mathbb R^2\to\mathbb R^2[/tex] would just be the identity function, right? Since it is just a coordinate transformation. The pullback of the identity function is the identity on forms, so the relation [tex]F^*\omega[/tex] is typical for coordinate transformations.
If [tex]F:(r,\theta)\mapsto (r\cos\theta,r\sin\theta),[/tex] which I'm suspecting he meant above, computing the form [tex]dx\wedge dy[/tex] in polar coordinates is the pullback by F itself, since the pullback is a contravariant functor. This is equal to the form itself since F is the identity but it is just expressed in a different coordinate system.
Note that F(r,O)=(rcosO,rsinO) is actually defined (at most) on (0,+\infty) x (0,2pi) in order for F to be a diffeomorphism. But clearly F is not the identity! The identity is Id(r,O)=(r,O).
Thank you for the post
I understand that [tex]F^*[/tex] pull the form on x,y R^2 back to polar
so the form would be expressed in polar R^2 as a pullback map acting on it
[tex]F^* \omega[/tex]
while this seems pretty good, I noticed Lee wrote in his later chapter, [tex]\omega = dx \wedge dy = r dr \wedge d \theta[/tex] kind of throw me off. Where is the pullback operator
or is it that he changes the coordinate chart instead of change the manifold the form is on?
That's it... if (x^i), (y^i) are coordinate charts around a point p in an abstract manifold M, a form w can be written locally around p wrt each of the coordinate systems.
This is what Lee is doing here. The manifold is R², the form is the form w defined wrt to the global chart (x,y) by w=dxdy, and now he's saying that around almost any point, this form can be written locally wrt to polar coordinates as rdrdO.
Hmm yea, Thanks for the reply!
Okay, now I'm confused. F sends a point to itself but does so by changing coordinates. If p:R^2->R^2 is the identity on M which gives global polar coordinates and c:R^2->R^2 is the identity on N which gives global Cartesian coordinates, then cp^(-1):R^2->R^2 is F itself since it sends (r,\theta) to (r cos\theta,r sin\theta). But this is a composition of identities so F is the identity.
(r,\theta) and (r cos\theta,r sin\theta)=(x,y) are the same point but just in different coordinate systems...
...I see now. Nevermind.
  • · Replies 73 ·
9K
  • · Replies 29 ·
  • · Replies 0 ·
  • · Replies 24 ·
