Mod. Arithmetic Proof: I don't see flaws in my logic, but it isn't working out.
The problem involves determining the values of a constant integer a such that the mapping f: Z → Z defined by f(x) = ax + b is a bijection. The original poster expresses confusion regarding their proof and the implications of their conclusions.
  • Participants discuss the conditions under which the function f is not bijective, questioning the implications of the original poster's conclusions about the mapping. They explore the necessity of considering the term b mod a and its impact on the bijection condition.
The discussion is ongoing, with participants providing insights and questioning assumptions. Some guidance has been offered regarding the importance of the b mod a term, and the original poster acknowledges a mistake in their reasoning. However, there is no explicit consensus on the correct approach yet.
The original poster indicates a struggle with the concept of onto functions and the implications of specific values of a, suggesting that there may be constraints or specific cases under consideration that affect the bijection property.
jdinatale
1. Homework Statement .
1. Let [itex]a[/itex] and [itex]b[/itex] be constant integers with [itex]a \not = 0[/itex], and let the mapping [itex]f : Z \rightarrow Z[/itex] be defined by [itex]F(x) = ax + b[/itex]. Determine all values of [itex]a[/itex] such that f is a bijection. Prove that the aforementioned values are the only possible values resulting in a bijection.
The logic in my proof makes sense, but my conclusion that [tex]ax \cong 0 \mod a[/tex] doesn't make sense because that statement will always be true.
N/A
What's wrong with always being true? The only way f(x)= ax+ b will not be bijective is if there exist [itex]x_1[/itex] and [itex]x_2[/itex] such that [itex]x_1\ne x_2[/itex] but [itex]ax_1+ b= ax_2+ b[/itex]. What does that tell you about a?
I understand that it will always be 1-1.
But my whole issue is that you could construct a [itex]f(x) = ax + b[/itex] that is not onto. For example, consider [itex]f(x) = 4x + 3[/itex]. There is no [itex]x \in \mathbf{Z}[/itex] such that [itex]f(x) = 5[/itex].
That's my whole problem.
You seem to have lost the [itex]b\mod a[/itex] term in your argument. Considering it should lead you to the correct condition.
Thanks for point that out, I did mess up there. It should be [itex]ax - b \cong b \mod a[/itex]. I don't quite see how this helps because that implies that [itex]a[/itex] must divide [itex]ax - 2b[/itex]. I don't see how that tells me anything about what a must be. I mean it tells us that [itex]a must divide [itex]2b[/itex] for this to be true. <br /> <br /> But anyways, at the end of the day, we know [itex]a[/itex] must divide [tex]t - b[/tex][/itex][tex]. The only number guaranteed to divided every integer [itex]k = t - b[/itex] for all integers [itex]t[/itex] and [itex]b[/itex] is 1. The problem is finding a mathematical argument for that. Given any other a, I could always find a number such that the function isn't a bijection.[/tex]
I apologize for double posting, but it will no longer let me edit my last post. I believe I have found a solution, but I would greatly appreciate it if you could look through it and try to find errors.
  • · Replies 16 ·
