Can Two Discontinuous Functions Become Continuous When Added Together?
The discussion centers on the mathematical concept of combining two discontinuous functions to create a continuous function. Participants suggest using functions such as F(x) = 1 for x ≤ 0 and F(x) = 0 for x > 1, and G(x) = 1 for x ≤ 0 and G(x) = 0 for x = 1. However, it is established that simply adding these functions does not yield continuity due to domain issues. A valid approach is to define G(x) as G(x) = 1 - F(x), which can lead to a continuous result when properly defined.
  • Understanding of discontinuous functions
  • Knowledge of function definitions and domains
  • Familiarity with basic mathematical operations on functions
  • Concept of continuity in mathematical analysis
  • Research the properties of discontinuous functions in calculus
  • Study the concept of continuity and its mathematical definitions
  • Explore the method of defining functions piecewise
  • Learn about the implications of function domains in mathematical operations
Mathematics students, educators, and anyone interested in understanding the behavior of functions in calculus, particularly in the context of continuity and discontinuity.
semidevil
just a basic question, so if I'm asked to find 2 functions that are discontinus, but when added together, becomes continuous, how do I approach that?
can I say like, let
F(x) = 1 for x =< 0, and f(x) = 0 for x > 1.
G(x) = 1 for x =<0 and g(x) = 0 for x = 1.
can I just somehow "add" f + g and say that is continuous? I don't know...tips?
Let f be your favourite discontinuous function, then let g=1-f.
Prove g is discontinuous, and hence find a continuous function that is the sum of two continuous ones.
Your f and g, did you mean to capitalize them? Note g doesn't have the same domain as f; g isn't defined for any positive real numbers, and hence neither is f+g.
can I say like, let
Well, you can't just say it's continuous- because it isn't!
(f+ g(x)= 2 for x<0, 1 if x= 0 and 0 if x>0
(I've switched the last "1" to "0". The f and g you give are not defined between 0 and 1. Unless that's a typo, I have the uncomfortable feeling that you don't know what is meant by "defining" a function.
Taking f(x)= 1 for x<= 0, f(x)= 0 for x> 0, which is not continuous at x= 0,
try matt grimes' suggestion. What is g(x)= 1- f(x)?
