Solve Calculus Problem f(x)=(ax+b)/(x-c)
  • Thread starter Thread starter needhelpperson
    Calculus
The function f(x) = (ax+b)/(x-c) exhibits symmetry about the y-axis, has a vertical asymptote at x = 2, and its derivative at x = 1 equals -2. The value of c is confirmed to be 2, leading to the equation -ca - b = (1-c)^2 * -2. By substituting c into the equation, it is established that b = -2a + 2, which allows for the determination of a, b, and c through the derived equations.
  • Understanding of calculus concepts, specifically limits and derivatives.
  • Familiarity with properties of even functions and symmetry in graphs.
  • Knowledge of algebraic manipulation and solving systems of equations.
  • Ability to apply logarithmic identities in calculus.
  • Study the properties of even functions and their implications in calculus.
  • Learn about limits and vertical asymptotes in rational functions.
  • Explore the application of derivatives in determining function behavior.
  • Review logarithmic identities and their use in calculus problems.
Students and educators in mathematics, particularly those focusing on calculus, algebra, and function analysis. This discussion is beneficial for anyone seeking to understand the properties of rational functions and their derivatives.
needhelpperson
f(x) = (ax+b)/(x-c) has the following properties
i) the graph of f is symmetric with respect to the y-axis
ii) lim x->2^+ f(x) = + infinite
iii) f^prime (1) = -2
a) Determine the values of a, b and c.
i think c = 2
derivative of f(x) = (-ca - b)/(x-c)^2
so f^prime(1) = -2
-ca-b = (1-c)^2 * -2
if c = 2 then b = -2a + 2
I'm stuck from here. I have no idea how to do this. I tried using this equation
(ax+b)/(x-2) = (-ax + b)/(-x-2)
since symmetric over y-axis and i plugged in b, but it turned out to be useless. Please help. thanks
The equation will be competely determined if you have 3 equations for these three unknowns (a,b,c).
Your equations should be:
1) f(x) = f(-x) for the first condition (an even function)
2) as x goes to 2^+(f(x)) the funciton blows up. the only way the function can blow up is if the numerator goes to infinity or the denominator goes to zero. The numerator will still be finite in this limit so the denominator has to go to zero. so you should have 2^f(x) -c =0 take the natural log of both sides and you should get f(x) = ln c / ln 2 (look up your identities in a math table if this doesn't seem familar)
3) f'(x=1) = -2
tiger-striped-cat: I suspect that "ii) lim x->2^+" was meant as "limit as x goes to 2 from above, not 2f(x). In that case, you just have to note that the denominator, x-c, must be 0 when x= 2: 2- c= 0. c= 2 as in the initial post.
Saying that "the graph of f is symmetric with respect to the y-axis" means, as tiger-striped-cat said, that f(x)= f(-x). Instead of doing that in general, just look at a few values of x: if x= 1, f(1)= (a+b)/(1-2)= (-a+b)/(-1-2)= f(-1); if x= 3, f(3)= (3a+b)/(3-2)= (-3a+b)/(-3-1)= f(-3). You may not even need the derivative!
  • · Replies 69 ·
