Difficult Indefinite Integral (substitution problem?)
The discussion revolves around the indefinite integral of the function \(\int \frac{x}{\sqrt{x+8}} \, dx\). Participants are exploring substitution methods to simplify the integral.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants suggest various substitutions, such as \(u = x + 8\) and \(u = \sqrt{x + 8}\), to simplify the integral. Some express uncertainty about the effectiveness of these substitutions and question whether they are missing something obvious in their attempts.
Several participants have provided suggestions for substitution, and there is an ongoing exploration of different approaches. While some methods appear to simplify the integral, there is no explicit consensus on the best approach, and participants continue to discuss the implications of their choices.
Participants are working within the constraints of a homework assignment, which may limit the information they can use or the methods they can apply. There is a recognition of the need to manipulate expressions correctly to facilitate integration.
Ocasta
[itex]\int (\frac{x}{\sqrt{x+8}}) dx[/itex]
I got to be honest, I don't even really know where to start with this problem. So bear with me as I take a wild stab in the dark. This section was substitution problems, ...
[itex]\frac{x}{\sqrt{x+8}} = \sqrt{ \frac{x^2}{x+8} } = <br /> <br /> <br /> <br /> [/itex]
Try putting u = x+8, that should help you along.
Even better: try putting sqrt(x+8) = u.
RGV
RGV
[itex] <br /> u = \sqrt{x+8} \rightarrow du = (1) \frac{1}{2 \sqrt{x+8}} dx<br /> [/itex]
I don't think that helps...
[itex] <br /> u = x+8 \rightarrow du = 1 dx<br /> [/itex]
I don't think that helps, either. Am I missing something obvious?
Ocasta said:
[itex]u = x+8 \rightarrow du = 1 dx[/itex]
Yes. There's an x on the numerator of the integrand. If u = x + 8, x = ...
Like stated above, u=x+8 makes the integral much simpler to solve.
If you apply Mr. Vickson's method, you need to write [itex]u^{2} = x + 8[/itex], which leads to [itex]2u du = dx[/itex]; in the numerator, you then replace the remaining x in the numerator with u2 - 8 . More than one approach works for this integral.
I ended up going,
[itex] u = x + 8[/itex]
[itex] x = u - 8[/itex]
[itex] \int [u-8]/[sqrt(u)] du[/itex]
[itex] \int (u-8)u^{-1/2} du[/itex]
[itex] \int u^{1/2} - 8u^{-1/2} du =[/itex]
[itex] c + \frac{2}{3} u^{3/2} - 16 u^{1/2}[/itex]
[itex] c + \frac{2}{3} (8+x)^{3/2} - 16 (8+x)^{1/2}[/itex]
Thanks everybody!
Ocasta said:
I ended up going,
u = x + 8
x = 8 - u
Your method is fine, but look at this again.
gb7nash, I went back and fixed that problem.
Hey guys, thanks to all of you! You've been a great help.
  • · Replies 105 ·
13K
  • · Replies 22 ·
  • · Replies 22 ·
  • · Replies 27 ·
