Solve f(x) = (ax+b)/(x-c): Determine a,b,c
  • Context: Graduate
  • Thread starter Thread starter needhelpperson
    Calculus
The discussion revolves around solving the equation f(x) = (ax+b)/(x-c) under specific conditions, including symmetry, limits, and derivatives. Participants explore the implications of these conditions and attempt to determine the values of a, b, and c.
  • One participant suggests that c = 2 based on the limit condition.
  • Another participant calculates the derivative of f(x) and relates it to the conditions given, but expresses uncertainty about how to proceed.
  • Some participants question the validity of the problem, suggesting that there may be no solution for a, b, and c as stated.
  • A later reply indicates that the original question may have been misstated, proposing an alternative form of the function that could potentially lead to a solution.
Participants generally agree that the original problem may not have a solution, but there is disagreement regarding the correctness of the initial conditions and the formulation of the problem.
There are limitations regarding the assumptions made about the function's form and the conditions provided, which may affect the ability to find a solution.
needhelpperson
f(x) = (ax+b)/(x-c) has the following properties
i) the graph of f is symmetric with respect to the y-axis
ii) lim x->2^+ f(x) = + infinite
iii) f^prime (1) = -2
a) Determine the values of a, b and c.
i think c = 2
derivative of f(x) = (-ca - b)/(x-c)^2
so f^prime(1) = -2
-ca-b = (1-c)^2 * -2
if c = 2 then b = -2a + 2
I'm stuck from here. I have no idea how to do this. I tried using this equation
(ax+b)/(x-2) = (-ax + b)/(-x-2)
since symmetric over y-axis and i plugged in b, but it turned out to be useless. Please help. thanks
Check the question again, and the 3 conditions. As the question is stated, I don't think there's any solution for a,b and c.
I agree. There seems to be no solution.
thanks for your time. This was all my teacher's fault. He didn't give us the correct question. It was (ax+b)/(x^2-c). Wow what a waste of time. I solved it anyways though, and again thanks for all your time.
  • · Replies 0 ·
