Solving 1= \frac{2^{x+1}}{x}: Is There a Trick?
  • Thread starter Thread starter cragar
The discussion revolves around the equation 1 = \(\frac{2^{x+1}}{x}\), which is being analyzed for potential solutions. Participants are exploring the nature of the equation and whether it can be solved using algebraic methods or if numerical approaches are necessary.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss various attempts to manipulate the equation, including multiplying by x and taking logarithms. Some express frustration at circular reasoning encountered during their attempts. Others introduce the Lambert W-function as a potential avenue for complex solutions and suggest numerical methods for solving coupled equations.
There is a recognition among participants that the equation may not have real solutions, with some suggesting that complex solutions could exist. Multiple interpretations of the problem are being explored, particularly regarding the consideration of complex numbers.
Some participants note that the question is posted in the Precalc section, implying a focus on real numbers, which raises questions about the appropriateness of considering complex solutions in this context.
cragar
[itex]1= \frac{2^{x+1}}{x}[/itex]
I multiplied both sides by x and then tried taking the ln of both sides but it just seems like you go in circles. Is this solvable with some trick?
Equations like that can't normally be solved by algebraic methods. You must use numerical methods. However, this particular equation can be shown not to have any real solutions.
It's not straightforward. It is solvable in terms of the so-called Lambert W-function. The solution is complex. Here it is in Maple 14:
eq:=2^(x+1)/x=1;
(x + 1)
eq := -------- = 1
x
sol:=solve(eq,x); evalf(sol);
sol := -1/ln(2)*LambertW(-2*ln(2))
.1279196207-2.181686754*I (I = sqrt(-1) in Maple terminology)
Alternatively: you could write x = a + I*b and get a set of two coupled nonlinear equations for a and b, then solve them numerically using a Newton-Raphson method or something similar.
RGV
You're right about going around in circles.
[itex](x) 1= \frac{2^{x+1}}{x} (x)[/itex]
[itex]x= 2^{x+1}[/itex]
[itex]\ln(x)= \ln(2^{x+1})[/itex]
[itex]\ln(x)= x \ln(2) + \ln(2)[/itex]
[itex]\ln(x) - \ln(2) = x \ln(2)[/itex]
[itex]\frac{\ln(x)}{\ln(2)} - 1 = x[/itex]
This will give you an x = something, but you still have x in both sides of the equation.
I think there is no real solution. When I plot x and 2(x+1)...they do not intersect. However if x is imaginary, you get one extra d.o.f and a family of solutions exist.
Suppose x=a+ib. Then your equation becomes two equations (one for Re, and one for Im), these are:
a=2(a+1)(cos(b ln(2))) and b=2(a+1)(sin(b ln(2))). The ratio of these gives a=b/tan(b ln(2)). Thus the family of solutions is x= b/tan(b ln(2))+ib with |b|< [itex]\pi[/itex]/(2 ln(2))
ok thanks for the answers
Since this question was posted in the Precalc section, I'm going to assume that the domain for consideration is real numbers. In that case, I agree with ritoban5 that there is no real solution, and in that context, that would be the answer.
cragar,
Is there some reason we should consider the complex numbers as possible solutions?
  • · Replies 24 ·
  • · Replies 39 ·
  • · Replies 17 ·
